Could the Freewing F/A-18E Hornet V2 90mm be hand launched? At our field the grass might be to long for this landing gear.
RE: Freewing F/A-18E Hornet V2 90mm
Wow, I would have to say no. This bird takes an abnormal amount of surfaced runway to achieve t/o speed normally, but having never tried hand launching cant say for sure. Would be very surprised if it worked.Originally posted by garyjetCould the Freewing F/A-18E Hornet V2 90mm be hand launched? At our field the grass might be to long for this landing gear.
CT
Thanks for the the info now the big question what is the difference between the V1 and the V2...thrust vs weightOriginally posted by fredmdbudYes, it can be hand-launched, especially if you reduce the weight by removing the landing gear. I've been able to hand-toss my V1.
Here's a video of one being handlaunched:
https://www.youtube.com/watch?v=JQp1q1n7RrA
Dam! Would never thought this bird could be h/l. What size Lipo used?Originally posted by fredmdbudYes, it can be hand-launched, especially if you reduce the weight by removing the landing gear. I've been able to hand-toss my V1.
CT
I've used both single 6S and serially-connected 2x3S batteries. Just adjust battery position to maintain CG.
Apart from the EDF unit and motor, then only differences between the V1 & V2 are the removable wings, separate flaps, and ball links on the stabilators. Not much of a weight difference there. The V1 also used a 6-blade fan.
If you have >1:1 thrust-to-weight ratio at launch, the plane will practically fly out of your hand at full throttle.
Yep I used to hand toss my V1 (same overall airframe and weight as the V2). It's not that hard once you remove all of the LG. It's not a simple toss, you really have to put some muscle into it but it's entirely possible.
The video is a good indication of how to do it properly. 10+ degree AoA into a good head wind and give it a level, vigorous toss and off she goes!My YouTube RC videos:
Hand toss on the V2 is possible, I've done with with an Admiral 6s 5000mAh 50c, with the landing gear removed. Strong, level toss into a slight headwind, on high rates.Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
Plus the empty wheel compartments from the mains act as a perfect grip location!My YouTube RC videos:
This is a V1 in the video but with a light 6s 4000mah battery you can just let it go when made light enough. Takes a certain skill level obviously. Not a 100% sure this can be done with the V2 as the V1 seems much lighter but the V2 does have more thrust so you never know. Either way I wont be trying what this guy does in the video with either my V1 or V2 but if your good enough then what hay. Enjoy. https://www.youtube.com/watch?v=--jp84KFbbU
