Flap to Elevator mix for FW 90mm F-15 ???
  • RMatteson
    Captain Rick
    • 62
    I have looked and have not got a answer to flap to elevator mix on Freewings 90mm F-15. There is a down setting for stab neutral, no where does it say about flap mix. Could one of you guys flying this let me know what to mix in?
    Thanks Rick
  • DCORSAIR
    • 1918
    • Selma, Ca.
    If I remember correctly, it doesn't need any, mine flies fine with no flap/ele mix, it drops the nose a little but nothing bad, maybe others will chime in on what they use.
    • RMatteson
      Captain Rick
      • 62
      Hey any of you F-15 pilots, what do you have in your set up???
      • Rcfiddy1
        Professional Crash Test Dummy
        • Aug 2015
        • 186
        • Manalapan, NJ
        I just swapped out stock hp version to a fw inrunner housing with fms 12b fan and leopard 4082-200kv...still waiting to remaiden.
        • DCORSAIR
          • 1918
          • Selma, Ca.
          FW 4068-1680kv, stock ESC, flies excellent, way better than stock. I did try the FMS 12 blade/1900kv and it was no better than the stock 1550 to me so I went to the HP set up from FW.
