Found an assembled, but never flown Habu 32x on fb marketplace. It was set up with all the recommended stock equipment from eflite, so after the maiden, first thing I did was order an fms 12 blade edf & 100a esc combo for it. That delta 32 5 blade unit is obnoxiously loud . The stock esc location was not good either, sandwiched between the 2 intake ducts. Lack of airflow had the stock 80a esc getting so hot it was cutting off. So when I installed the new edf i put the esc right below it & made a custom air scoop for it. Plan to test it tuesday after work. (Scoop in the pic was just placed there for the photo.) Finished product is centered better.
