Freewing T33 mods
  • Vlyter
    • 22
    Freewing T33 mods
    I just finished building the Freewing T33. I added navigation lights to the tip thanks using the Freewing L39 lens covers. I added speed brakes wired with the flaps. I added a spot light to the nose gear strut positioned directly in front instead of the side of the strut. I used the spot light from the Freewing F14.
  • James
    Administrator
    • Aug 2017
    • 1543
    Welcome to HobbySquawk Vlyter ! Way to make an entrance! That looks fantastic! :punch:
    • hotrod23t
      jim jets
      • Nov 2017
      • 312
      • EUSTIS FL.
      Log into Facebook to start sharing and connecting with your friends, family, and people you know.
      • hotrod23t
        jim jets
        • Nov 2017
        • 312
        • EUSTIS FL.
        My light mods and air diverter
        • hotrod23t
          jim jets
          • Nov 2017
          • 312
          • EUSTIS FL.
          Louver upgrade
          • Vlyter
            • 22
            Did you just paint it red and then put the stars on it how did you do that
            • Vlyter
              • 22
              Is that a 3-D printed part
                • Nov 2013
                • 2793
                • Cody, WY
                Great Job!! How did you route the wires from the wingtips to inside the fuselage through the wings?
                • Vlyter
                  • 22
                  I made a small channel down to the ailerons servo and then used the servo wire channel already built into the wing for the balance of the distance to the center of the wing. I sprayed 1" tape bright silver and covered the new channel. Very simple.
                  • hotrod23t
                    jim jets
                    • Nov 2017
                    • 312
                    • EUSTIS FL.
                    the scoops were painted red and i used old waterslide decals for the stars i desined the scoops on tinker cad and 3d printed them on ver 4 now lots of pics of light install on rectangle rc facebook..air diverter ver 4 has 4 intakes intsead of 3
                    • hotrod23t
                      jim jets
                      • Nov 2017
                      • 312
                      • EUSTIS FL.
                      oh and no need to route wire to fuse thay plug in wing boards and run through the ribbon connectors
                      • hotrod23t
                        jim jets
                        • Nov 2017
                        • 312
                        • EUSTIS FL.
