I put a trailing link from the 90mm F15 on the nose as we fly off grass. Needed to be drilled out to accept the larger trunion on the FMS retract, and the front door cover wont work/fit.
Try changing out the tires first use dick browns I don’t buy FMS always a retract issue while your at it change out the speed controllers the generally suck as well hope this helps
