Question about upgrading to "bigger" EDF
  • Beeg
    Originally posted by Crick3t
    Ok that makes sense. Can you link it for me please? I'd love to read through it, but i'm having trouble finding it.
    Is this the only air frame (f35) you tried it on? Do you think other platforms might be better suited to doing something like this? I am pretty sure the freewing f-18 comes setup to run either 80 or 90mm fan.
    I've been trying to find info on doing something like this and have had no luck until your replies TiredIronGRB
    Your knowledge is greatly appreciated!!!
    Are you looking for thrust, flight time or just wanting to tinker? You can always change the motor and/or fan without changing EDF diameter.
  • mshagg
    Chalk another failed experiment squeezing an 80mm into an F35 here.
    This stuff is reasonably complex, there's a lot of trade offs and considerations in the design of the intake and exhaust ducting. I think alpha has made some pretty detailed posts on the topic.
  • Crick3t
    Not enough air intake, it would barely get off the ground...I did a write up on here on HS.
    Not enough air intake, it would barely get off the ground...I did a write up on it here on HS...
  • Crick3t
    Why though? Just saying it was a turd doesn't really do any good. Yes it implies it was not a good upgrade, but why? Weight issue? Battery issue? Intake or Outlet size issue? What did you do to figure out it was a turd? Did you just fly it and go by what you heard or saw / felt?
    I'm trying to get some good input if anyone has experience with this.
    Thanks.
    I am wondering if anyone has played around with swapping out EDF's in their jet's for a bigger size? For example if you have an F35 70mm putting an 80mm edf unit in it. Or taking any 80mm jet an putting a 90mm unit in it.
    Are there efficiency gains / power gains / or is all of that lost with weight and bias changes ?
    If anyone has experimented or just up and done this I'd love to hear about the results.
    Thanks!
    I put an 80mm in my F-35 and it was a turd
  • Crick3t
    started a topic Question about upgrading to "bigger" EDF
    Thanks!
