Newbie need some help
  • Rcnewby
    • 24
    Can someone out there answer this question for me I recently purchased An f18 hornet 4 ch it was their $139 one I also have an FMS coursair 4 channel with an FMS transmitter and receiver no I can put that in the hornet and it will work correct I’m new at this just getting into it Thanks for the help
    • 5401
    Probably...
      • 8814
      It appears that the F-18 can take the same receiver as the Corsair, so one can predict that it will be able to use the same transmitter. Since you have both in your Corsair, it's easy enough to just yank out the receiver and put it into the F-18 and give it a try. No need to bind it since it's already bound. Just check it to make sure all the control surfaces move in the correct direction when you move the sticks.
      • Rcnewby
        • 24
        Ok thanks viper
