The modern Freewing EDF system is very, very good in the EDF market today, in terms of value and performance. If you really want the next step up from the Freewing system, you'll need to go German. They are not cheap, but these fans are a work of art. They are more efficient than the Freewing system with about the same performance. This means you can go with a higher Kv motor and get higher performance than the stock Freewing system, and still maintain similar flight time. The recommendations are as follows (assuming using 6S):
1. Wemotec Midi Fan Evo 90mm with HET 650-68-2000:
https://shop.wemotec.com/Midi-Fan-ev...onically-tuned
2. Jetfan 90 with HET-700-60-2085:
3. The crown jewel of EDF: Schubeler DS-51-AXI with HET-700-68-2100
https://www.turbines-rc.com/en/schub...100-motor.html
All three options are very expensive, but it can "wake up" your 90mm jets. They also have fantastic turbine sounds. The sound is so good, you can hardly hear any motor whine at all. I've only upgraded two of my six 90mm EDF jets because of the cost, but the performance is unrivaled.
looking for aftermarket power systems
I went with the 1835kv 4068 12-bld. inrunner for my F-22 on 6S, but still waiting for it to arrive.
Heard good reports it helps in the F-16, but it is really heavy. I like the F-18 high-performance option conceptually, because it's both less expensive and lighter. In addition, with the 9 bld. fan, likely is slightly more efficient.Leave a comment:
Hey ochoaoctavio89@icloud.com, welcome to HobbySquawk! Freewing has been in the process of upgrading all the outrunner motors stock with stock inrunner motors . The F-18 already now has the High-Performance option that includes this inrunner: https://www.motionrc.com/products/fr...inrunner-motor
Unfortunately it is out of stock as a stand-alone at the moment, but they are on their way. That power system should benefit any of the jets you mentioned. Just click the 'notify me when back in stock' button on the page and when they arrive, you will be notified.Leave a comment:
I recently sold all my 70-80mm jets and got all the 90mm nice planes they just feel a little under powered specially the F-16 i now own f4,f15,f16,f18,and f22 i want to upgrade the edf units and maybe the speed controller if i have to on my jets but iwanted to start with the f16 can n e one point me the right direction if i should do inrunner or outrunner and witch power system will wake up my f-16 thanksTags: None
