64mm Freewing F9F engine not working
  • Anzios
    • Jul 2019
    • 4
    I just recently bought the Freewing F9F from motion rc and after gluing it together and plugging everything into the reciver I plugged in the battery and nothing throttle related works. Ailerons and elevators work but the engine while the sound that said its bound went off the fan isn't turning on and when i unplugged the battery i noticed the ESC was warm. Can yall help me fix this.
  • Coconut
    • Apr 2019
    • 212
    Have you tried calibraitng the ESC? If you do it make sure the trim tab is set to -100. What you may also try is going to Travel setting for Throttle. Increase it to about 120. It's going to be the lower value. Then with the battery disconnected put the throttle stick all the way up, so you have access to the upper value. Increase that to 120, also. It should work fine. That's what I did.
