RETRACT PROBLEM
  • GLYNGYRO
    • Oct 2020
    • 4
    RETRACT PROBLEM
    Freewing Venom Nosewheel tries to extend before doors are fully open and tries to retract before doors are fully open
    • 8835
    Is it the stock nose retract? Or did you replace it with a different one? If it's the stock one, then find the sequencer and check where everything is plugged in. It may be possible that you've got the retract plugged into the gear door pins and the gear door is plugged into the retract pins.
