E-flite su 30 issue
  • Bonde
    • Mar 2019
    • 5
    E-flite su 30 issue
    I bought myself an eflite su 30 twin 70mm, but I can't get it to take off from grass. Does anyone in here have any good solutions for that.
  • bandetx
    • Nov 2017
    • 88
    What is your c rating of your battery? What size battery? Remove the mud guard on the front landing gear for less drag against the grass.
    • Bonde
      • Mar 2019
      • 5
      Bandetx.
      I have already Remove the mud guard.
      6s 6000mah Weight is 714 Grams, C rating 30 At one and 50 on two others all is 6000mah.
      I have extended front wheel struts by 17 millimeters (About half an inch)
      • bandetx
        • Nov 2017
        • 88
        The 30c rating battery wont work well for edfs. 50c is fine.
        Without adding any tail weight, a 6000 pack at the front will have it noseheavy which makes it harder to rotate. I use a 6000 6s on mine, and I have afterburner lights installed at the back, and it's still nose heavy.
        Some options:
        Carve out a bit of foam at the front so you can move battery further back
        Add tailweight
        Seperate your ailerons to 2 channels so you can mix Flaperons.
        • bandetx
          • Nov 2017
          • 88
          Also, make sure to calibrate your ESCS so you are getting the most thrust you can!
          • Bonde
            • Mar 2019
            • 5
            Thanks Vandetx
            I'll try some of your suggestions.
            Hav you try to go into esc programming, I didn't succeed in the ordinary way, full throttel and connect the battery to etc. I can't get into the program. Have you been successful with it.
            • bandetx
              • Nov 2017
              • 88
              Don't need to go to esc programming.
              Just power on tx->full throttle->plug in battery to plane->beep(s)->zero throttle->beep(s) esc calibrated
