What happened to Failsafe?
This topic is closed.
  • Pilotguy
    • Mar 2015
    • 196
    • Las Vegas, NV
    Pilotguy
    • Geo: Las Vegas, NV
    #1What happened to failsafe?
    Yesterday, 10:43 PM
    I turned on my Spektrum DX6 then plugged in the 6S battery to my Freewing F-86 80mm getting ready to fly. For some reason I wanted to check the trim settings in “trim utilities”. When you do that the trim utilities menu alerts you that the “RF Output will be Reduced”. When I continued into the trim utilities, all of a sudden the EDF spooled up even with the throttle stick all the way back at idle. The airplane rolled off until my brain caught up and I exited the “trim utilities” . The receiver is Spektrum AR620. I can’t figure out why the EDF throttled up with reduced RF output. If anything I would expect the failsafe to kick in and cut power to the EDF ( since the failsafe should have set when I last binded the Airplane). Any ideas? Thank You
    • 8835
    Perhaps you should answer Fred’s questions in the other thread you started and see where that leads.
      • 5426
      The failsafe was set to full throttle, de do it.
        I agree and further more this thread is actually in violation of the Hobby Squawk Code of Conduct under the title of Spamming.
        SPAM/FREE ADVERTISING
        Spamming (where someone posts the same message in multiple threads) is prohibited.
        For this reason I am closing this thread.
        Regards,
