Looking For My Next Jet
  • Stuka
    • Oct 2020
    • 30
    Guys,
    I am looking to get an EDF. I prefer it to be built up or composite and run on 6/12S or 5/10S both 5000mah These are the batteries I already own. What kind of options do I have? Thanks in advance.
  • dahawk
    Augermeister
    • Jun 2013
    • 1006
    • Keller,Texas
    Stuka,
    There's a lot out there but don't let your existing stock be the only driver.. In 6S you have a wide range of Freewing 80mm and 90mm edf's. Not all can handle more than 8S. Depends on the ESC. 8S will require at least a 130 amp esc. I flew the F4 on 8S ( 6+2) 6000mah. A little more oomph than the stock 6S but not radically faster. Better vertical for sure but top end speed was only marginally faster, maybe 5-10%. I regularly fly the T-33, A4, L-39, F/A-18 90mm with a RCjetwerx 6S 6000. Looking for easy? The F-86 is a blast. I have a FMS 2000 in mine. Plenty fast. Fly it wit a 6S 4500 or 6S 5000. Cheers, Hawk
      • 5401
      I didn't answer since he's not wanting a foam EDF... Not really the place to come to but I'm sure there is someone familiar with 12-14S composites...
      • Stuka
        • Oct 2020
        • 30
        Evan D
        Yes you are correct I’m looking for something that’s not foam. I didn’t think by the title of this forum It was foam only. If so let me know and I will close or move the topic. Thanks
          • 5401
          Nope, you are fine. Most who post here a foam EDF pilots though...
          Here might be better... Large EDF Jets - RC Groups
          • Stuka
            • Oct 2020
            • 30
            Evan D
            Thanks I will check over there as well. Appreciate the help.
            • Jschwab
              • Jun 2019
              There are some very nice EDF Jet Wood Kits that you might like, for example https://www.turbines-rc.com/en/42-je...cells_-8s_296v
              or https://www.rc-builder.com/collections/edf-jets
              also EDF Jet power units https://www.rc-builder.com/collections/edf-jets
              Hope this helps!
              • Stuka
                • Oct 2020
                • 30
                Hope this helps!
                Thank you I'll check them out.
