I recently got passed this extreme flight plane with a dx6e controller. I believe the plane is 60” long and it came with 2 batteries the plane the controller and a charger. There is also this circuit board thing if somebody can tell me what I need to do to make this work I would appreciate it.
I need help learning how to set up my plane
Yup, that's the balance board. To balance charge a LiPo, you must connect that board to the charger with the appropriate connector. From there, the battery connects to the charger via the yellow XT connector on the board and then connects to the balance board via its balance plug. The charger is set to balance charge at the proper rate (ie, "1C" or at the amps of the battery X 1). If there is a setting on the charger, it should be set for the number of cells of the battery.
You might want to check out some YouTube videos on the subject to actually see what's being done.
