Hi All; my Freewing F-15C came in good shape from Singapore today. Took a few weeks but they did a good job, overall.
I have the plane basically together, but am hoping someone can give me a confirmation on where to put the horizontal stabilizer per the instruction manual, which was unclear to me, at least
If I'm reading it correctly, it says to put the stabilizer leading edge 10mm down (nose up trim) from, what I'm guessing is the actual neutral. or the horizontal seam on the fuse. So, am I doing it correctly if I have the leading edge of the stabilizer down from that seam 10mm for the correct neutral position for flight?
Thanks for any help on this!
Regards,
Davegee
Regards,
Davegee
