Eflight SU30 ailerons not working! Help please!
    It's really not necessary to start another thread on this. You should look at the first one you started yesterday and give it a chance.
  • RRHandy
    Plug the ailerons into another channel to see if it's the receiver or the servos, if you have a servo tester use that to see if the servos move and if they do then check wiring bask to receiver.
  • Riv3973
    started a topic Eflight SU30 ailerons not working! Help please!
    So today I unboxed my eflight su30. Put it all together, wanted to take it out to my street to just taxi it around since the sun was down. I put the battery in bind the trans. And checked all the gear and movements of everything. Everything worked as it should but the ailerons. The wings are getting power because the lights are coming on but no movement. My transmitter is a Spectrum NX6 in which I have flown all my other planes just fine with… the draco, Cub as 2.1 and the extra 300. What are some of your thoughts? Transmitter settings?? Even when the plane goes through the motions to show you it’s bind was successful they do not move.
    thanks in advance
