Gyro as delivered how to adjust gain?
Freewing B2 bomber
Have you not been reading along with the main B-2 thread. That's been talked about for a while now. You can't change the gains without the programmer, which is only available at the moment from RC Castle. Motion's are coming. You can also try to hook up the master gain to a rotary and dial down the gains. You just can't dial them up with this method.
B-2 Spirit Bomber Twin 70mm EDF Jet from Freewing B-2.jpg (filedata/fetch?filedataid=79728) Watch the video here: https://youtu.be/CntgqHwbpCY Join us for a Live Overview and Q/A This Friday, April 8th at 12pm EST: https://youtu.be/BxKyzOx_L_g Fly the ultimate RC jet by Motion RC! The Freewing B-2 Stealth Spirit -
Correction ............................. You CAN dial up the gains IF you increase the servo travel over 100% in your TX's servo travel menu. But be careful. The roll gain is already a bit too much if you fly really fast.Have you not been reading along with the main B-2 thread. That's been talked about for a while now. You can't change the gains without the programmer, which is only available at the moment from RC Castle. Motion's are coming. You can also try to hook up the master gain to a rotary and dial down the gains. You just can't dial them up with this method.
https://www.hobbysquawk.com/forum/rc...n-70mm-edf-jetComment
