The XK Model A180 F-22 RTF is a great introductory jet model aircraft for beginners due to its built-in stability system (3D/6G) that supports smooth flights and resistance to crashes.
The powerful brushed motor supports a wide flight envelope for flying everything from stable flight to impressive aerobatics. The XK Model A180 F-22 boasts attractive scale looks in a grey camo military scheme and comes with LED lights for nighttime adventures. If you are looking to get into the hobby with a smaller jet with a built-in gyro for stability and nice scale looks the XK Model A180 F-22 would be a terrific choice.
Features:
- Comes with 3D/6G, a gyro for increased stability and helps decrease the chance of a crash. Simply cycle between 6G (stable mode) and 3D (no control surface limits) by pressing the aileron stick to the lower left after activating the model
- Made of EPP material, lightweight, high flexibility and crash-resistant
- Compact size and nice scale looks appeals to both novice and advanced pilots
- Powerful brushed motor supports a wide flight envelope from stable to aerobatic flight
- LED lights for dusk/dawn flights
- XK Model A180 F-22 with Gyro 320mm (12.5") Wingspan - RTF
- FTR Futaba S-FHSS Compatible 4CH 2.4GHz Transmitter
- 2.4GHz Receiver
- 2S 7.4V 300mAh LiPo Battery
- 2S LiPo Battery Charger
- USB Charging Cable
- Replacement Propeller
- Owner's Manual
- Four (4) AA size batteries for the radio transmitter – we recommend Admiral NiMH Rechargeable Batteries
HELPFUL TIP: If you are new to radio control (RC) we recommend that you read through our RC resource known as our "Knowledge Blog". It's jam packed with helpful information for beginners including how to articles, support videos, a glossary of terms and much more. Click Here to go to our Knowledge Blog's Beginner Section. For further assistance, please do not hesitate to contact our Customer Support Team and one of our knowledgeable RC experts will be glad to assist you. Happy flying!
Product Specifications:
AGE LEVEL:14 and up
SKILL LEVEL: Beginner
BUILD TIME: None
| Model Scale | N/A |
| Wingspan | 320mm / 12.5in |
| Length | 452mm / 17.7in |
| Weight | 80g / 2.82oz |
| CG (Center of Gravity) | Refer to the manual |
| Power System | Brushed motor (included) |
| Electronic Speed Control | N/A (included) |
| Propeller / EDF | Pusher propeller (included) |
| Servos | Micro |
| Landing Gear | Fixed (included) |
| Required Battery | 2 Cell 7.4V 300mAh LiPo battery (included) |
| Radio | 2.4GHz (included) |
| Ailerons | No |
| Elevator | Yes |
| Rudder | No |
| Flaps | No |
| Lights | Yes |
| Hinge Type | Nylon |
| Material | EPP Foam |
| Skill Level | Beginner |
| Build Time | None |
