64mm a10 nose gear upgrade?
  • Jolls070707
    • Dec 2021
    • 3
    Is there any nose gear strut that I can swap in to have some suspension? I’ll fly off of grass and the original plastic one is not cutting it.
    • 8835
    Are you willing to do a little work (if necessary) to make it work? Take a look at the front nose gear strut from the 70mm F-35 Lightning. It's the same pin diameter.
    • RRHandy
      Instructor Pilot
      • 898
      • Lilburn GA
      FMS (E-flite) 64mm A10 has the oleo strut you are looking for, the freewing strut I assume you have.
      AMA 424553
