Mirage 2000; Gyro/Radio setup question
  • Lateral-G
    • Sep 2022
    • 23
    I have the Mirage 2000, Admiral RX600P stability gyro and the Spectrum NX8 radio.
    What is the proper way to set up the gyro and radio?
    Do you use the elevon mix in the radio and the normal wing setup on the gyro?
    or
    Do you use the delta config dip sw settings on the gyro and configure custom mixes with the radio?
    Which rx ports should be used?
    AIL & ELE
    AIL and AX1
    AIL and AX2
    I've tried several configs and have not had success.I can get the basic control surface to function but when I switch on the gyro they do not work as they should (ie one surface functions the other doesn't or the surface move opposite of each other or they don't move at all)
    Looked for posts or videos but not much on my situation.
    Any help is appreciated,
    • 5426
    Answered in other thread
    • Lateral-G
      • Sep 2022
      • 23
      got it sorted...thx
