Freewing B2 Bomber Spare Parts
  • AdrianT
    • Mar 2023
    • 3
    I've managed to break to the elbow joint that connects the ball link to the servo for the drag rudder, does anyone know where I can get a replacement part(s)?
    • 8835
    Are you talking about the servo arm? The part that attaches to the servo? Or the other end - control horn?
    If it's the servo arm, you can buy the servo arm kit or the whole servo that should come with the arm. You may have to enlarge the holes that the ball link would go into. Look at the B2 product page and see "parts".
    If it's the other end on the control surface, that's might be a bit more difficult. You may have to use something like liquid steel epoxy and glue the horn back on. Or buy the whole rudder surfaces. They'll come with the horn.
    • AdrianT
      • Mar 2023
      • 3
      Thanks for the prompt response, it's much appreciated.
      It's the white plastic bit the holds the ball links and attaches to the servo cog.
      Do you have a link to the kit by any chance?
      Thanks!
        • 8835
        Here is the whole servo with the arms:
        You also just buy Freewing 9g servo arms:
        Buy Freewing Servo Horns for 9g Digital Servos online at Motion RC. Order online with fast delivery.
        Surely, you must have some servos that you've taken out of crashed Freewing planes that you can pirate the arm from and just drill out the hole at the appropriate distance from center to attach the ball link?
          • 5426
          I'm 99% sure the B2 has it's own type of servo arms. I also remember someone from Motion said there is no servo or plastic parts kit that come with them....
          From memory.
          Edit.
          This- Freewing Twin 70mm B-2 Spirit Bomber Pushrod [FJ3171111] Motion RC​
            • 8835
            From memory.
            Edit.
            You're right. Those are weird ones. 3D print or liquid steel the broken one. Buy the pushrod set. AdrianT .......... don't get the things I posted or you'll need to do some heavy mods on those horns.
            • Tom
              Super Moderator
              • Sep 2013
              • 905
              AdrianT, I'm not 100% sure which part you are talking about. If you can post a picture, I'll see if we have it. If not, I'll get a new SKU created and order it.
              BTW, if any of you ever need a spare part you can't find, call or email our customer service team. If they can't find it, ask them to create a "new parts order request". they will likely do that anyway but it does not hurt to ask. All the guys know how to do it. That will log the part needed so we can create a new SKU and order the part. We check those every time we place a new order.
              • GliderGuy
                • 1416
                They come in the push rod spare parts kit….
                https://www.motionrc.com/products/fr...hrod-fj3171111
                Follow the link and look at the photo. I believe you will see what you are looking for….bottom left side of the photo.
                -GG
                • AdrianT
                  • Mar 2023
                  • 3
                  Thanks everyone the pushrod kit has what I'm looking for in it. :-)
