Version Info: This is the V2 version of the 64mm F-22. This model includes a new updatedmotor and 12B EDF, updated fuselage mold, upgraded ESC with thrust reversing capability, digital metal gear servos, and a new more scale paint scheme.
Introduced in 2005, the F-22 Raptor is the US Air Force's ultimate super-maneuverable, stealth fighter aircraft. The clean lines, stealth profile, and scale details are all captured in this exceptional 64mm EDF Jet from Freewing Models. Simplicity and durability were major design factors with this model. All airfoil surfaces (main wings, rudders, and elevators) are attached to the fuselage using a new modular joiner system which improves strength and allows easy parts replacement.
Quality electronic components come pre-installed so you can be in the air in less then one hour. This High Performance version of the F-22 includes an upgraded 2850Kv outrunner motor, 12-blade fans, 40A ESC with thrust reverse and 4 Cell LiPo capability, making it the perfect EDF Jet for those pilots seeking higher top-end speeds and faster climbing rates. This plane is one of the Motion RC Flight Team's favorites - fast, easy to fly and affordable. Own a piece of US Air Superiority today - the Freewing 64mm V2 F-22 Raptor.
Visit the product page here: https://www.motionrc.com/products/fr...t-pnp-fj10513p
- NEW! Includes a powerful 2840-2850Kv outrunner motor and 12-Blade EDF unit
- NEW! 40 Amp ESC with thrust reversing capability
- NEW! Updated fuselage (complete new mold)
- Full size, independent elevators provide level flight and improved aircraft climbing ability
- Main wing, rudder and elevators are all detachable making the aircraft easy to transport and easy to repair (no gluing)
- Fixed, scale landing gear design helps keep the F-22 lightweight and also improves the model's flying life
- Large ESC cooling vents help extend the life of the on-board electronics
- Nylon hinges on all control surfaces (superior to foam hinges)
- Durable EPO material is stronger and more flexible than conventional foam airframes
- Brushless motor, ESC and servos come pre-installed for your convenience
- 4 Channel radio - select a minimum 4 channel radio from our Radio Collection
- 4 Channel receiver - select a minimum 4 channel receiver from our Receiver Collection
- 4 Cell 14.8V 2200 mAh LiPo Battery with XT60 Connector - EPR22004PROX6
- 4 Cell compatible battery charger - select a minimum 4 cell (4S) charger from our Charger Collection
AGE LEVEL :14 and up
SKILL LEVEL :Intermediate
BUILD TIME :1 Hour
| Wingspan | 690mm / 27.2in |
| Length | 950mm / 37.4in |
| Flying Weight | 850g / 29.98oz |
| Power System | 2840-2850Kv brushless outrunner motor |
| Speed Control | 40A, XT60 Connector, internal SBEC |
| Propeller / EDF | 64mm 12-Blade EDF |
| Servos |
| Landing Gear | Fixed main landing gear, steerable nose gear |
| Required Battery | 4S 14.8V 1600mAh to 2200Ah 30C LiPo |
| Required Radio | 4 Channel radio |
| Rudder | No |
| Flaps | No |
| Ailerons | Yes |
| Lights | No |
| Hinge Type | Nylon hinges on all control surfaces |
| Material | EPO Foam |
| Skill Level | Intermediate |
| Build Time | 1 Hour |
