Super Scorpian Power Set-up
  • Patternpilot
    • 4
    Anyone running the stock set-up with a 4000mah 6s 60-80c pack ? If so, just curious what kind of flight time you are getting from it. Thanks
  • Alpha10
    J e t - J u n k i e
    • 377
    • Chicago
    Depending on your throttle management I'd say between 2:40 and 3:10 minutes. Unfortunately, the stock setup takes about 3/4+ throttle to fly well so it shortens the flight time pretty quickly.
    Upgrading is well worth it in terms of performance AND better flight times IME.
      On the stock setup with the Admiral 6s 4000mAh 60c my timer is set for 3:30. Set your timer for 2 minutes for your maiden, check your battery, and gradually increase your timer in 15 seconds increments until you're consistently landing at ~25% charge remaining. Throttle management, battery quality, air thickness, air temperature, and other factors can impact your flight time.
