Official Freewing Zeus 90mm EDF Sport Jet Thread
    Are you changing the timing? Have you put a watt meter on it to see?
    Again I don't know of anyone saying they have had a problem with the ESC failing even using HV batteries. If people make modifications or change settings I could see problems arising but haven't heard of any.
    Do you have a link to these reported failures?
  • Fredardi
    Others says that on Zeus 8s the problem is the motor timing that exceed the max amps on the esc... I want to be sure before my maiden.Thanks for your replay !
    The Zeus electronics, ESC with the BEC have proven very reliable. The new 120A 8S reversible ESC is now in all the 90mm FreeWing plane, both 6S and 8S. Could there be a bad one, sure, but...
  • Fredardi
    Just received my Zeus 8s ...what a great model.Someone is reporting on socials that he have crashed it due to a failure of the. stock esc especially on excess timing of the motor and a bad Bec ,he suggest to put an external one to be safe .Did you have any failure on your zeus due to electronics ?
  • Fredardi
    Hello, did the ZEUS 8s will re-stock soon on Motion EU ? I wanted to order for Christmas but it is month that is out of stock...
    No advantage. Go with what makes sense money wise.
  • drscoles
    I'm a turbine guy, not well versed on EDF. Have a ton of 6s 5000 packs, are most of you guys just adding a 2s 5000 to get to 8s? I see someoene above was using two 4s packs.... Does either combo have an advantage?
  • deadbug
    Flight time is totally dependent on your throttle management style. I have my timer (throttle output+25%) set for 3:30 but monitor telemetry flight pack voltage as the real landing decision. When not doing any speed runs and using mixed throttle for acro I am getting 4 mins or so till I hit storage voltage (30.4) inflight at or near idle…and land. Multiple speed runs and I'm at 3-3:30.
    i only use SMC LiHV flight packs charged to 4.35V per cell (see maiden report you quoted above),
    DB​
  • WWIIP38
    Originally posted by deadbug
    8S Maiden Report:
    Late this afternoon I completed the maiden plus two additional flights.
    CG exactly on factory marks with gear down (since nose gear retracts forward)
    All control horn positions moved in towards servo by two holes--using the third on from the end.
    All control deflections matched the manual settings except elevator in HIGH (100%) . As I suspected, book deflections, especially the elevator were way too much for this type of jet. Flap settings are per the manual.
    Maiden = 2X SMC 4S 5900 HCL/HVP
    2nd Flight = 2X SMC 4S 6200 HCL/HVP
    3rd Flight = 2X SMC 4S 5900 HCL/HVP
    RX =Spektrum AR8360T SMART with AS3X and SAFE (maiden conducted gyro-off)
    Observations:
    I was actually pleasantly surprised with how the airplane flew once I got it trimmed up. With my gyro off, I conducted stalls clean and in the landing configuration with full flaps, upright and inverted spins, attemped snap rolls with only pitch inputs--no rudder--upright and inverted. Also tried inverted loop--was successful in low rate elevator (who wants to do that though)--but in 100% high rates (remember I moved my elevator control horn out of the "3D" factory position) she definitely snapped out of the maneuver. Not dramatic but definitely wants to snap pushing forward on the stick. I can imagine if Evan used full book elevator why that got his attention When my gyro was in the AS3X flight mode, it was noticeably more resistant to snaps.
    I noticed no unusual behavior during the full aft-stick stalls in any configuration--nothing different than other sport jets (other than the Avanti) and definitely much more tame than the Havoc Xe.
    I was really surprised that I did NOT notice any nose-down tendency when pushing up power to full during a go-around or low pass.
    Landings really reminded me of the Havoc--my first few were purposely fast, then I started slowing them down and even tried holding it off until the stall (but just an inch or two above the runway) Unlike the Havoc, which would drop a wing if you breathed to hard during the flare, I couldn't get the wing to drop even when running the 2 X 4S 6200's. I wouldn't try holding it off though unless you could keep it within an inch or so of the runway.
    At the CG marks--I found that I did NOT need the down flap/elevator mix the manual gives. I got rid of them on the second flight. Flew on final so much better and the flare was nicer. Note my stab trim at Book CG in pic below. I am feeling compelled to move it back as I just don't like the up elevator trim required at that CG.
    Thrust Reverse - Well I was disappointed--it helped a bit, but not as effective for braking as other jets I have. I have a mix set with the reverse channel mixed with throttle, so all I have to do after touchdown and in idle is hit my "G" switch full up and it goes to 100% reverse power.
    All in all I like the jet and will continue to explore her performance envelope. Oh, I did have a broken cloud layer a little bit of haze and I did find the airplane a little difficult to see when I was high and the sun wasn't shining on the plane. When it did--it stood out nicely. The upper fuse EPO above the intakes is softer than I'm used to--put a nice thumbprint dent on it as I was rotating the airplane off the stand.
    I didn't do any speed runs today--I was more interested in exploring the flight characteristics. Those are easy and will be later. Hope this helps those who are waiting to maiden theirs.
    DB​
    ​ Click image for larger version
Name:	Zeus elevator trim.jpg
    Great report! What flight times are you getting on 8S? Favorite batteries?
  • MetallDanny
    The keys here are stay at Factory CG, and reduce the factory 3D Elevator throw!
    Thank you for the Tips !!!!
  • deadbug
    Hey Danny--read my maiden review above and on RCG. Has everything you need. I flew it again today (first time since maiden day a week ago). Verified that unlike most models, factory CG is really where you want to be--I conducted test flights throughout the entire envelope with CG at factory, and then at factory CG +5mm aft. It is very noticeably more prone to snaping (spin entry--or commonly here: tip stalls) at the 5mm aft of factory CG both upright and inverted with pitch inputs ALONE (no rudder or aileron). This was really consistent. The same can be said for stalls in the landing configurations--both partial and full flaps: It would smartly drop a wing with and without gyro after the stall with the CG 5mm aft of factory with High, Medium or Low rate elevator. At the factory CG, it tended to buck a bit but resisted wing-drop unless you input aileron. I can imagine the stability decreases even more the farther you move aft of the Factory CG +5. If all you do is speed runs, it may not be a factor for you. However, it probably will during landing and flare unless you fly very fast on final and the flare--lol.
    I measured gear down rightside up since the marks were under the wing and used my EZ Lite CG Balancer rig.
    DB
    [QUOTE=MetallDanny;
    CG from the BOOK ??
    upside down with Landing gear out ?
    any other suggestions [/QUOTE]
  • MetallDanny
    Last week I bought the ZEUS 8s
    a couple days later the box from MotionRC arrived woohoooo
    but uhmm it was the wrong model :scream:
    they send me the 6s noooooo
    quickly I send a email to MotionRC
    (and I saw that the last 8s model was out of stock arrgh)
    I picked up my phone and called them.
    in short: bla bla bla sorry send it back !!!
    but but its going to take days noooo
    I jump in my car and drove to them the next day (2hours on the highway)
    Click image for larger version  Name:	D0121E80-22C9-4FA2-ABDF-674C30189DD6_1_201_a.jpg Views:	48 Size:	176.8 KB ID:	390574
    yesyesyes my box was still in the warehouse !!!!!!
    hopefully tomorrow I can do the Maiden (weather is very bad last couple days)
    SPEKTRUM AR8360T
    Click image for larger version  Name:	B428B7B9-3404-4F77-B3BE-1E23F1024AF4.jpg Views:	14 Size:	98.4 KB ID:	390575
    SPEKTRUM SMART 6S/5000 + 2S/5000
    Click image for larger version  Name:	5182B322-2952-4C8B-BB4C-953C0314FF15.jpg Views:	14 Size:	93.8 KB ID:	390576
    :warning: CG from the BOOK ??
    I haven’t because I want to keep the simplicity of the ribbon cables. Once I get more flights I may split the aileron wire off the ribbon cable and go straight to the receiver and do some crow. Or I may put a gyro in it… That should help too.
  • tclaridge
    Has anyone tried a slight crow setting at full flap? I hear about the wing drop at full flap, and a little aileron reflex may fix that. On my Habu32, I added a little aileron reflex at full flap, and it helps stability in the landing configuration at slow speed as this delays the tip stalling first.
  • MetallDanny
    😳 292kmh
    Nice maiden report! Well done.
  • deadbug
    Thanks Danny--not a simple answer as I have all my AS3X gains set up as "adjustable, set up two separate gain channels one for ailerons & rudder and one for pitch modulated by my iX20 sliders underneath the transmitter: The 100% 1X AS3X gain values I programmed in the RX are: ROLL 68; PITCH 88; YAW 72. I normally keep the sliders right in the middle, so that gives me 1/2 of the values resulting in 34, 44, and 36 respectively. If I'm in the pattern on a really windy gusty day when slowed down, I'll increase one or more of the sliders up to the max as necessary to make her more "on rails" in the gusty winds.
    DB
  • MetallDanny
    Thank you for this extensive informative report deadbug !!
    Did you adjusted the stock AS3X Gains?
    can you throw some numbers ?
  • deadbug
    8S Maiden Report:
    Observations:
    DB​
  • MetallDanny
    Originally posted by Jake Bullit
    THE Metal Danny? 😎
    Haha 😄
    Yes yes I'm still alive !!
