Zeus 90mm EDF Sport Jet from Freewing
The 90mm Zeus is the latest sport jet offering from Freewing. Featuring a sporty and highly aerodynamic design, the Zeus 90mm is Freewing’s fastest sport jet yet, reaching speeds of 130 miles per hour (210 kmh) in level flight. Additionally, the blue, grey and white livery offers an attractive, bold presence that can be seen easily in the skies. Impressively designed, the wings are glue and screw-free utilizing a quick release wing lock mechanism that makes installing and removing the wings a simple and quick experience.
Each control surface is managed by a 17 gram metal gear servo for quality and confidence. Offered in 6S, 8S and ARF PLUS, the Zeus promises to deliver the most powerful thrust-to-weight ratio of all the Freewing sport jets before it. Take to the skies and experience the incredible thrill and neck-turning speed of the Zeus!
Feel The Need For Speed? The Freewing Zeus 90mm EDF is the fastest sport jet developed by Freewing to date. At 130mph straight-line speed out of the box (6S PNP), the Zeus is sure to quench your thirst for acceleration. |
Quick-Install & Release Wings The Zeus 90mm EDF features a screwless quick release wing design that makes field assembly and disassembly a breeze. |
Slow Your Roll The Zeus includes a thrust-reversing ESC (PNP versions) enabling a brake-like effect, effectively reducing your roll out on landings. This is especially useful on shorter, paved runways. |
Grass Friendly The Zeus 90mm EDF sport jet comes with CNC-machined struts with a trailing link design that can handle most reasonably-mowed grass fields with ease. |
Navigation and Position Lights The Zeus features daylight-bright LED lights on the wing tips, top and bottom of the fuselage, as well as a landing light that is mounted on the nose gear strut. |
Vivid Color Scheme The color scheme on the Zeus is bright and vivid, providing great visibility in all types of situations and conditions. |
Great Sound and Power The Zeus 90mm EDF 6S PNP sports the new 12-blade 90mm EDF unit with a powerful 3668-1960Kv inrunner motor for high end EDF jet performance. |
Full Landing Gear Doors The Zeus has fully sequenced gear doors, including inner main gear doors for lower drag and better sport jet performance. |
- Our fastest 6S sport jet yet, capable of speeds of 130mph (210kmh) in level flight
- Sleek, aerodynamic design for incredible sport jet performance
- Quick release main wings provide a simple and easy process for installing and removing the wings
- CNC-machined landing gear struts with trailing link design for better grass-field operations
- Daylight-bright LED lights located on the wing tips, top and bottom of the fuselage and a landing light on the nose gear strut
- 12-blade, factory-balanced EDF combined with a 3668-1960Kv (6S) or 4075-1350Kv (8S) brushless inrunner motor for top end EDF jet performance and great sound
- 120 Amp ESC with 8A UBEC with thrust reversing
- (7) 17g, digital, metal gear metal gear servos for all control surfaces
- (2) 9g, digital, hybrid metal gear servos for nose gear steering and nose gear doors
- Fully sequenced gear doors, including inner main gear doors for lower drag and better performance
- Nylon hinges on all control surfaces
- Freewing Zeus 90mm 6S EDF Sport Jet - PNP
- 12-Blade EDF power system (installed)
- 3668-1960Kv brushless inrunner motor (installed)
- 120A ESC with reverse thrusting and EC5 connector (installed)
- Electronic retractable landing gear (installed)
- Servos, LED Lights (installed)
- 7 Channel radio - select a minimum 7 channel radio from our Radio Collection
- 7 Channel receiver - select a minimum 7 channel receiver from our Receiver Collection
- 6 Cell 22.2V 5000 mAh LiPo battery with EC5 connector - we recommend the Admiral 6 Cell 5000 mAh LiPo with EC5 connector
- 6 Cell compatible battery charger - select a minimum 6 cell (6S) charger from our Charger Collection
AGE LEVEL :18 and up
SKILL LEVEL :Intermediate
BUILD TIME :1 hour
Model Scale | N/A |
Wingspan | 1200mm / 47.24in |
Length | 1450mm /57.08in |
Empty Weight | 2820g / 99.47oz (w/o battery) |
CG (Center of Gravity) | 120mm (4.7") from the leading edge of the wing at the root |
Power System | 6S 3668-1960Kv Brushless Inrunner Motor |
Electronic Speed Control | 120A thrust reversing, EC5 Connector |
Propeller / EDF | 90mm 12-Blade EDF |
Servos |
Landing Gear | Electronic retractable main gear and steerable nose gear with all metal shock absorbing struts |
Required Battery | 6S 22.2V 5000mAh LiPo with EC5 connector (required) |
Required Radio | 7 Channel (required) |
Ailerons | Yes |
Elevator | Yes |
Rudder | Yes |
Flaps | Yes |
Lights | Yes |
Hinge Type | Nylon Reinforced |
Material | EPO Foam |
Skill Level | Intermediate |
Build Time | 1 Hour |
Recommended Environment | Outdoor, 150+ foot paved runway or short manicured grass |
