RC Jet Engine?
  • robertmurphy
    • Mar 2024
    RC Jet Engine?
    Hello,
    I love RC and I built a few RC cars here and there, some electric and some gas, but I want to get into RC planes. I planned to spend around 500 dollars on the plane itself, no higher, because that's all I got for spending on my hobbies.
    I literally just found out RC jet engines were a thing two days ago. They are all pretty expensive ~2000 dollars and more, so I was wondering if there were any less than or equal to 1000 USD? Just having it would be cool.​
  • kallend
    • 1877
    If you want an inexpensive model of a jet, an EDF is the only real option. Turbines are expensive and likely to stay that way.
    • kylemcgee
      • Jul 2024
      Getting into RC planes sounds like an exciting new venture! Here's some information to help you out:
      1. RC Plane Options under 500 USD: There are several options available within your budget of 500 USD for RC planes. Look for models that are suitable for beginners if you're just starting with RC planes. Brands like E-flite, HobbyZone, and FMS offer good entry-level planes that fit this budget.
      2. RC Jet Engines: Indeed, RC jet engines can be very expensive, often exceeding 2000 USD. These are typically used in high-performance jet models and require additional investment not only in the engine itself but also in the airframe and electronics.
      3. Alternative Propulsion Systems: Instead of jet engines, you might consider electric ducted fan (EDF) systems for a jet-like experience without the high cost of a turbine. EDF setups can be more affordable and still provide a similar look and feel to jet aircraft.
      4. Budget for RC Jet Engines: While many RC jet engines are indeed costly, there are some smaller or less powerful turbine engines that can be found for around 1000 USD or slightly more. Companies like KingTech Turbines offer options in this range, but it's crucial to check specifications and suitability for your intended plane.
      5. Consider Used or Second-hand Options: Another option to explore within your budget is looking for used RC planes or engines. Websites like RCGroups, eBay, or local RC clubs often have classifieds where you can find good deals on slightly used equipment.
      6. Research and Compatibility: Before making a purchase, ensure that the engine or plane you choose is compatible with your skill level and the type of flying you intend to do. Also, factor in additional costs like batteries, radio equipment, and any necessary accessories.
      • kallend
        • 1877
        ChatGPT strikes again?
          If you drive rc cars and do well, I would suggest starting with trainers still. Jets tend to hit the ground much harder and faster. Landings are always the most essential part of flying. You might be able to get it off the ground fine, but not understanding the dynamics of a nice smooth damage free landing takes time and experience. You have to thread the needle between steady decent and stall all the way to touchdown. The problem is, if you stall, you're done, you hit too fast, you're done. For rc aircraft, best way to learn is crawl, walk, run. Do not rush development, it always leads to failure one way or another.
          • shortround91
            • Nov 2023
            • 301
            • Princess Anne, Maryland
            Definitely agree I have a room full of busted planes EDF Jets from when I started out 10months ago. Start with a Trainer then low wing like a Trojan T28 then progress. Jet wise I went 50 Habu several 64 F16 70 F16 Mirage 80 (3) 90 J10 90F15 twin 80 F14. It’s a slow progress and weather permitting I flew every single day, nice thing being retired. Just take your time you will crash it’s life get used to it but much easier to take. $2-300 plane total than a 500-1k plane been there done that didn’t feel good
