Has anyone used a jeti radio to do thrust reversing on avanti v2 or any other freewing jets with thrust reversing esc. Looking for the correct setup on the radio
Avanti V2 Thurst Reversing using Jeti Radio
Tags: None
I don't understand the problem. I just plug the reversing lead into a spare switched channel, and it works. The Freewing reversing ESCs are just re-labeled Hobbywings.
What is your exact setup, and what problems are you having? -
I had to pre-program the reverse thrust.
so first set the chanel you want to use, and the button in the (in spektrum anyways) chanal asign. Than you can also pre make the mix from aux(what chanel you used) to throtle than bind the plan. Worked for me anyway.Comment
