4s battery with Freewing F86 80mm
    Poof. Unless you put in a 8S ESC and then you need to baby the motor.
  • PikeStaff
    2 of ‘em in series would be plenty good (This is not serious, you understand.)
    No. You might be okay with 5S but no way with 4S.
  • Easystik
    started a topic 4s battery with Freewing F86 80mm
    Hi, I'm thinking about buying the Freewing F86 80mm. I have many 4S batteries already, and I don't want the plane to go particularly fast, but have enough thrust to take off from grass. Can I safely use a 4s battery with a 6s set up, and this plane in particular? Thanks.
