The Aero L-39 Albatros, developed by Aero Vodochody, is a legendary jet trainer known for its versatility, precision, and enduring legacy. Designed in the 1960s as the world’s first turbofan-powered trainer, the L-39 quickly became a cornerstone of military pilot training worldwide, revered for its agility and light-attack capability.
The Black Horse L-39 Albatros Turbine ARF captures the scale detail and commanding presence of this iconic jet in a large 1:5.5 scale model with a wingspan of 1890mm (74.4”). Designed for turbine power, this ARF accommodates jet engines producing 100–140N of thrust for impressive speed and performance. Constructed with precision from all balsa and plywood, the model comes pre-covered in high-quality heat-shrink film with factory-printed scale details for added realism. Fully electric retract gear with durable oleo struts and a control box is included, ensuring smooth, reliable operation. This massive L-39 is perfect for pilots looking to take their turbine jet experience to the next level.
Factory-Printed Covering The model is covered with durable heat-shrink film featuring factory-printed scale details for stunning realism right out of the box. |
Electric Retract Gear with Oleo Struts Fully electric retract gear with robust CNC oleo struts and included control box ensures smooth and reliable operation. |
Turbine-Ready Power Designed for turbine jet engines producing 100–140N of thrust, delivering breathtaking speed and performance. |
Detailed Cockpit Interior Features a fully detailed cockpit with painted pilot figure, instrument panel, and realistic seating for ultimate scale realism. |
- Massive 1:5.5 scale design with a commanding 1890mm wingspan
- High level of prefabrication right out of the box
- Lightweight, strong, precision laser cut balsa and plywood construction
- Heat-shrink film covering with factory-printed scale details for added realism
- Fully electric retractable gear with robust oleo struts and controller box (included)
- Optimized for turbine jet engines producing 100–140N of thrust (not included)
- Spacious servo mounts (41x21mm) for HV high-torque servos (+ 1 size: 35 x 16mm)
- NACA airfoil design for smooth, stable, and precise flight characteristics
- Pre-hinged control surfaces for easy assembly
- Large, easy-access hatches for straightforward installation and maintenance
- Painted and detailed cockpit, pilot and interior included
- Fiberglass control horns
- Comprehensive control and fitting accessories included
- Two-piece, plug-in wings simplify transportation and assembly
- Black Horse L-39 Albatros 120N Turbine 1890mm (74.4") Wingspan - ARF
- Electric retract gear with oleo struts and controller box
- Detailed assembly and instruction manual
- 8 Channel radio - select a minimum 8 channel radio from our Radio Collection
- 8 Channel receiver - select a minimum 8 channel receiver from our Receiver Collection
- Turbine Engine - 100–140N thrust rating (recommended)
- 9x high torque servos - we recommend Hitec D-645MW High Voltage High Torque Digital Metal Gear Servo Airplane Multi-Pack (8 Servos) and 1 HS-7245MH High Voltage High Torque Digital Metal Gear Mini Servo
- Receiver Battery – 2200-3200mAh 6.4v LiFe for standard voltage receiver or 7.2v Lipo battery for high voltage receiver
- 2 Cell compatible battery charger - select a minimum 2 cell (2S) charger from our Charger Collection
Black Horse ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
AGE LEVEL :14 and up
SKILL LEVEL :Advanced
BUILD TIME :8+ Hours
| Model Scale | 1:5.5 Scale |
| Wingspan | 1890mm / 74.4in |
| Length | 2410mm / 94.8in |
| Weight | 13.8–14.9kg / 30.5–33 lbs |
| CG (Center of Gravity) | Refer to the manual |
| Wing Area | N/A |
| Wing Loading | N/A |
| Power System | Turbine jet engine with 100–140N thrust (required) |
| Electronic Speed Control | N/A |
| Propeller / EDF | Turbine jet engine with 100–140N thrust (required) |
| Servos | 9x HV high torque + 1x mini servo (required) |
| Landing Gear | Electric retracts with oleo struts (included) |
| Required Battery | 2S 6.4v LiFe or 2S 7.4V LiPo, 2200–3200mAh (required) |
| Required Radio | 8 Channel (required) |
| Ailerons | Yes |
| Elevator | Yes |
| Rudder | Yes |
| Flaps | Yes |
| Lights | No |
| Hinge Type | Nylon Heavy Duty pin hinges |
| Material | Balsa and plywood |
| Skill Level | Advanced |
| Build Time | 8+ Hours |
