Ar631
  • Ar631
    Is the spectrum ar631 a good choice for my f22 90mm I have nx8 I dont use thrust reverse or safe only as3x!
    An Ar637T will give you pack voltage telemetry and the possibility of adding a remote receiver in that expensive airplane.
      Depends on what you’re wanting to have, I run tailerons and the nose gyro which is super helpful from keeping wing tip overs from happening. For those types you will need a 8 channel the AR8360t is what I personally use in most of my jets or there 10 channel. I’ve had issues with the AR630 with faster jets so my suggestion is an antenna or duel even better. Like you I have safe AS3X+ and off there upgrade to plus is a huge difference in a great way
