can anyone id this f86? its 1100mm wing span 70mm edf...will maiden it tomorrow so maynot be all that important to find out who makes it lol
ID this F86
It's a Hobbyking jet Ron....
F-86 Desert Rats EDF Jet 70mm Electric Retracts, Flaps, Airbrake, EPO (PNF http://www.hobbyking.com/hobbyking/store/__17342__F_86_Desert_Rats_EDF_Jet_70mm_El...Lauren -
Vee haff vays.... LOL! I've got a bit of a knack for finding things on the web. What I did to find your plane was to go to Google images and search on "F-86 RC airplane" then all I had to do was find the image that matched your plane. I found it, opened the image by clicking on it then selected "Visit The Page" option and VOILA! there was the YouTube vid of it. :)LaurenComment
bought a 12 blade 4s fan with almost 3 lbs of thrust...planning a major overhaul....cant stand the long grass run (about 300 ft) before it flys... bad part is all the work and cost .. id probably be better off buying the freewing 80mm f86Comment
after a small repair to remove loose tape in the exaust tube I tested runway hog today...short vid
Couple of years old F86 i call runway hog. Only airplane i have ever maidened that didnt need any trim at allComment
I am an RC addict and innovator that loves to share my knowledge with those that need help. Ask me anything via PM if you need help! Check out my Website here https://www.gooniac33.me/Comment
replaced the nose gear and all the cheep plywood they had holding it in also the nose steering servo 3 more flights and seems to be holding up well...still a runway hog but flys so good I haven't even built the freewing f86 yetComment
