Lockheed U-2 Spyplane correct EDF
  • Edubarca
    • May 2025
    Hello my friends. I am plannin to make a U-2 Spyplane based on the plans designed by the late Jack Lynn Bale and available at Outerzone. I want to install an EDF instead of the glow engine TurboMax which is no longer available nor desirable. I fly at a high elevation of Bogotá, Coolombia which is 2.650 meters above sea level. Not counting with a high budget, I want to ask you which EDF you recommend. The Maximum diameter would be roughly 13 centimeters. Thank you very much for your help. EDUARDO
  • Edubarca
    • May 2025
    I forgot to mention that the wingspan of the model is 297 centimeters. Approximate weight will be about 12 pounds.
      • 4826
      Edubarca
      Welcome to Hobby Squawk, Sir, glad to have you onboard.
      If you have 297 cm of wingspan and 130 mm of maximum space, I would be looking at 120mm EDFs.
      You are building a size of model that is above my pay grade, but a 105mm or a 120mm which would be more than sufficient I would think.
      I would consider 8S as the battery size.
      Best regards, LB
