Freewing A-10 64mm V2 no throttle issue
  • Freewing A-10 64mm V2 no throttle issue
    I have the FW A-10 64mm V2 EDF. I have already had this jet up and running. I made a mistake and bound my F-16 profile to my A-10. I did a factory reset on my AR631 Spektrum receiver. It rebound fine. All the control surfaces work. No throttle though. I recalibrated it several times and nothing. I followed the directions for recalibration by starting my throttle position to high. Plugged in the battery and listened for the beeps. I immediately dropped the throttle stick down to the minimum. Still nothing. Im out of ideas. Any help would be appreciated. Thanks.
    Throttle kill enabled?
      No.
        Throttle trim at the very lowest? Sometimes, if you leave the trim in the middle where a new model always starts (Spektrum), it won't initialize because it thinks the throttle is too high. Check. Lower throttle trim to lowest (adjust throttle cut to below that point so it will work properly), rebind, recalibrate throttle.
