Engine Shutdown
  • Dulacraider
    • Jul 2023
    Engine Shutdown
    Hello, I am a little new to the EDFs and all that go with them. I have been having this issue with my Starboard engine. When I run the throttles up to full on the ground the starboard engine runs for a little bit and then shuts down. If I bring the throttles all the way back and run them up again the starboard engine picks back up. When it did it today I checked the batteries and both were reading over 22 volts. would this be indicative of a bad speed controller? (Freewing 80A Speed controllers)
    • 5426
    Probably just need the ESCs calibrated.
    • stojakovic
      • Mar 2024
      • 19
      exchange the two edf and Speed controllers,you will know where is the issue.
