FW F86
  • dkalwishky
    I use 1/2 power and once rolling straight full power.
  • Lon
    What throttle managment are you using for take off? 1/4 to 1/2 then to full once rolling?
    Depends on my mood, runway length, wind..:) First of all, like my single prop motor warbirds, I/you don't have to worry about the prop torque effect. You can hammer down to full throttle. If the club i'm at has the Long runway, I often slowly power up to 3/4 and do a long run scale take off. If i have to deal with a crosswind during take off, I'll put the hammer down to get her to rotation/liftoff speed asap, and anticipate a little raise maybe, from the wing that's into the wind. Take-off flaps(50%) make a significant difference on your speed/distance to take off.
  • AkumaZeto
  • AkumaZeto
    Glad everyone is having such success. I for some reason just am to worried I guess. Worried not only of her going but worried about a 100$ lighting on fire if it does go down.
  • Lon
    Originally posted by Chalredline1
    I had the maiden today. What a great plane. Only required 1 click of down to trim it for straight and level flight. Plane was very responsive and pretty much went where I pointed it. Take off and landings were very predictable and without issue. This one is already my favorite.
    Great to hear of your maiden today!!! She is a sweet flyer for sure. Only thing i find myself doing to insure greased landings, is talking to myself outloud those last few meters, keeping her inches above the runway as long as possible!
    Way to go! From talking with Lon at Nefi, and watching him fly his, it looks like a great bird. I like the idea that it has no prop factor to worry about and with tricycle L/G, it just steers like a car. In the air, to coin a phrase, it looks 'rock solid in the air'
    Glad to hear its love at first sight.
  • Chalredline1
  • AkumaZeto
    Mine still hangs from the ceiling. Still scared to put her up
  • Lon
    Fellows thanks for the battery advice. Can't wait to get this one and give it a go.
    Chalredline1...Have you got her in the air yet??
  • Chalredline1
    They will fit, you will just have to relocate the ESC so you can slide the battery farther back. I have been flying on Revolectrix 70C 6S 5500s and I do get a bit more flight time, about 4 min. However, like Roy said, it really performs better with the lightweight Admiral 4000s. Speed and vertical are improved significantly.
  • roys001
    I have one coming and have a question about the battery. I have some Turnigy 6S 5000mah 30-40C discharge batteries. Will they work in this plane as long
    as I carve out a bit for them to fit? They are about 1 7/8" wide, 2" tall and 5 3/4" long. They weigh a little over 750g. Just curious as I need to know if I need to buy some other batteries.
    Thanks,
    I have been using the 6s 5000 60c batteries from Turnigy for the last few months. They work ok but because of the increased weight they don't really add any time to the flight. I've bought two of the Admiral 6s 4000 60c batteries and wow what a difference. The 4k batteries are 12 oz lighter than the 5k. The flight times are the same but because of the lighter weight the plane performs better.
  • Chalredline1
    Thanks,
  • dkalwishky
    Originally posted by Lon
    Like Dave, i did 6 flights on the F-86 yesterday too. Hmmm...it's a toss up between the P-38 and 86, of which one i like flying the most.
    I love my P-38 as well. It's also a great flier.
    I saw Lon fly several flights with his and a dual flight with him and Ryan, what a great plane, not to take away from the pilots!!
    That might be a plane for Nefi next year, maybe I can swing a Sabre, hmmm.......
  • Lon
  • Flygirl
    Six flights on my F-86 yesterday, it's my favorite plane. She flies really nice with only one bad habit, the gear is narrow someone a crosswind mine has tipped over on the nose and wing.
    you can see what I mean in this video.
    https://m.youtube.com/watch?v=mE0p_aX25UU
    Sure looks pretty on final Dave!
  • dkalwishky
    Since the Dynam runs on 4S 5 blade fans, I would say that the F-86 is most likely faster. Max speed is around 85 mph on the stock setup. That said, it handles slow flight and wind pretty well. I took it out on Saturday in some pretty gusty conditions and it handled the wind miles better than my prop warbirds.
  • AkumaZeto
    Is it faster than the dynam me 262? Mine is still waiting maiden. After the 262 crash I have been leary
