Official Black Horse 2230mm Viper Jet Turbine 120N Discussion Thread
    • 8205
    Viper Jet Red/Blue Turbine 2230mm (87.8") Wingspan from Black Horse - Balsa Wood ARF - BHM1026-001
    SPECIAL NOTE PLEASE READ: This Viper Jet Turbine must ship via freight on a pallet. You must be home at the time of delivery to sign and help the driver move the plane into your garage. This product will not ship the same day due to the freight line pickup schedule. A $200 discount is available for customers willing to pickup this plane at the Motion RC warehouse.
    Sleek, fast, and purpose-built for turbine performance, the Black Horse Viper Jet 140N All-Composite ARF offers a premium alternative for pilots who prefer the strength and precision of molded composite construction. With a wingspan of 2230mm (87.8") and a flying weight in the 14-17 kg (31-37lb) range, this all-composite jet delivers a commanding presence in the air while maintaining the approachable handling Viper Jets are known for.
    The airframe is entirely hollow molded and built from lightweight composite materials for an excellent strength-to-weight ratio, resulting in a rigid structure with superb flying characteristics. The model comes fully painted at the factory with a high-gloss finish, giving the Viper Jet a polished, professional appearance right out of the box. A removable top hatch, along with removable wings and horizontal stabilizers, simplifies transport, assembly, and access to your turbine, tanks, and electronics.
    Optimized for a 140N class turbine, the Viper Jet includes electric retracts with full metal suspension gear, electric brakes, stainless steel tailpipe, ball linkages, and a high-quality hardware package. With its strong, lightweight composite construction and clean installation layout, the Black Horse Viper Jet 140N Composite ARF is an excellent choice for turbine pilots seeking a capable, large sport jet with refined performance and modern convenience.
    All-Composite Airframe
    The Viper Jet’s fully hollow-molded composite construction delivers exceptional strength with remarkably low weight. The rigid airframe enhances precision and responsiveness in the air, giving turbine pilots the crisp handling characteristics composite jets are known for.
    Electric Retracts with Oleo Struts and Brakes Included
    Included electric retracts with full-metal oleo struts and electric brakes give the Viper Jet reliable ground handling and confident takeoffs and landings. The retract controller box simplifies setup while adding dependable functionality in all field conditions.
    Built for Power
    Optimized for 120–160N turbine engines, the Viper Jet provides a clean and efficient installation layout that gets you in the air faster. A factory-supplied double-walled stainless steel tailpipe ensures proper turbine integration and heat management, making the setup process straightforward and dependable.
    Detailed Cockpit Interior
    The Viper Jet’s cockpit arrives fully finished with a painted pilot figure, molded instrument panel, and realistic seating for added scale presence. The clean, high-quality detailing enhances the model’s appearance both in flight and on the ground, giving this composite jet a polished, professional look straight out of the box.
    • Massive 1:3.8 scale jet with a commanding 2230mm (87.8") wingspan
    • Lightweight, high-strength hollow-molded composite airframe
    • Factory-applied high-gloss painted finish straight out of the box
    • Fully electric retractable landing gear with robust shock absorbing oleo struts included
    • Pre-hinged control surfaces for fast, straightforward assembly
    • Pre-installed, pre-hinged landing gear doors for added scale realism
    • Optimized for 120–160N gas turbine engines (not included)
    • Double-walled stainless steel tailpipe included for turbine installation
    • Spacious fuselage layout with organized servo mounts for clean installation
    • Aerodynamically efficient NACA airfoil for smooth, stable, and precise flight characteristics
    • Large, easy-access hatches for simplified installation and maintenance
    • Painted and detailed cockpit with pilot figure and interior included
    • Durable fiberglass control horns for precise control linkage
    • Comprehensive hardware and fitting accessories included
    • Two-piece plug-in wings and horizontal stabilizers for convenient transport and field assembly
    • Black Horse Viper Jet 140N Red /Blue (Turbine) 2230mm (87.8") Wingspan - All-Composite ARF
    • Electric retractable landing gear with full-metal oleo struts and controller box
    • Double-walled stainless steel tailpipe for turbine installation
    • Fiberglass control horns, ball-link hardware, and fitting accessories
    • Detailed assembly and instruction manual
    Requires:Customer Note
    This Black Horse ARF model is constructed out of composite materials. These are not foam models. The assembly of all-composite ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
    AGE LEVEL : 18 and Up
    SKILL LEVEL : Advanced
    BUILD TIME : 12+ Hours
    Model Scale 1/3.8 Scale
    Wingspan 2230mm / 87.79in
    Length 2173mm / 85.55in
    Weight 13.5kg / 29.76 lbs
    Wing Area 1,268 sq in / 81.8 sq dm
    CG (Center of Gravity) 195mm as measured from the wing root leading edge aft
    Power System Turbine jet engine with 120–160N thrust (required)
    Electronic Speed Control N/A
    Propeller / EDF Turbine jet engine with 120–160N thrust (required)
    Servos 11x HV high torque (required)
    Landing Gear Electric Retracts with Oleo Struts and Brakes (included)
    Required Battery 2S 6.4v LiFe or 2S 7.4V LiPo, 2200–3200mAh (required)
    Required Radio 10+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights Optional
    Hinge Type Nylon Heavy Duty pin hinges
    Material Composite Fiberglass, balsa and plywood
    Skill Level Advanced
    Build Time 12+ Hours
