Official Black Horse Viper Jet Turbine Composite 2230mm (87.8") Wingspan Thread
  • 3D-Seth
    • Mar 2023
    • 35
    Link to purchase:
    Viper Jet Red/Blue Turbine 2230mm (87.8") Wingspan from Black Horse - Balsa Wood ARF - BHM1026-001
    Sleek, fast, and purpose-built for turbine performance, the Black Horse Viper Jet 140N All-Composite ARF offers a premium alternative for pilots who prefer the strength and precision of molded composite construction. With a wingspan of 2230mm (87.8") and a flying weight in the 14-17 kg (31-37lb) range, this all-composite jet delivers a commanding presence in the air while maintaining the approachable handling Viper Jets are known for.
    The airframe is entirely hollow molded and built from lightweight composite materials for an excellent strength-to-weight ratio, resulting in a rigid structure with superb flying characteristics. The model comes fully painted at the factory with a high-gloss finish, giving the Viper Jet a polished, professional appearance right out of the box. A removable top hatch, along with removable wings and horizontal stabilizers, simplifies transport, assembly, and access to your turbine, tanks, and electronics.
    Optimized for a 140N class turbine, the Viper Jet includes electric retracts with full metal suspension gear, electric brakes, stainless steel tailpipe, ball linkages, and a high-quality hardware package. With its strong, lightweight composite construction and clean installation layout, the Black Horse Viper Jet 140N Composite ARF is an excellent choice for turbine pilots seeking a capable, large sport jet with refined performance and modern convenience.
    Visit the Official Black Horse Viper Jet Turbine 120N 2230mm Discussion Thread on HobbySquawk.com for additional photos, videos, reviews, and customer Q&A.
    All-Composite Airframe
    The Viper Jet’s fully hollow-molded composite construction delivers exceptional strength with remarkably low weight. The rigid airframe enhances precision and responsiveness in the air, giving turbine pilots the crisp handling characteristics composite jets are known for.
    Electric Retracts with Oleo Struts and Brakes Included
    Included electric retracts with full-metal oleo struts and electric brakes give the Viper Jet reliable ground handling and confident takeoffs and landings. The retract controller box simplifies setup while adding dependable functionality in all field conditions.
    Built for Power
    Optimized for 120–160N turbine engines, the Viper Jet provides a clean and efficient installation layout that gets you in the air faster. A factory-supplied double-walled stainless steel tailpipe ensures proper turbine integration and heat management, making the setup process straightforward and dependable.
    Detailed Cockpit Interior
    The Viper Jet’s cockpit arrives fully finished with a painted pilot figure, molded instrument panel, and realistic seating for added scale presence. The clean, high-quality detailing enhances the model’s appearance both in flight and on the ground, giving this composite jet a polished, professional look straight out of the box.
    • Massive 1:3.8 scale jet with a commanding 2230mm (87.8") wingspan
    • Lightweight, high-strength hollow-molded composite airframe
    • Factory-applied high-gloss painted finish straight out of the box
    • Fully electric retractable landing gear with robust shock absorbing oleo struts included
    • Pre-hinged control surfaces for fast, straightforward assembly
    • Pre-installed, pre-hinged landing gear doors for added scale realism
    • Optimized for 120–160N gas turbine engines (not included)
    • Double-walled stainless steel tailpipe included for turbine installation
    • Spacious fuselage layout with organized servo mounts for clean installation
    • Aerodynamically efficient NACA airfoil for smooth, stable, and precise flight characteristics
    • Large, easy-access hatches for simplified installation and maintenance
    • Painted and detailed cockpit with pilot figure and interior included
    • Durable fiberglass control horns for precise control linkage
    • Comprehensive hardware and fitting accessories included
    • Two-piece plug-in wings and horizontal stabilizers for convenient transport and field assembly
    • Black Horse Viper Jet 140N Red /Blue (Turbine) 2230mm (87.8") Wingspan - All-Composite ARF
    • Electric retractable landing gear with full-metal oleo struts and controller box
    • Double-walled stainless steel tailpipe for turbine installation
    • Fiberglass control horns, ball-link hardware, and fitting accessories
    • Detailed assembly and instruction manual
    Requires:
