Official Black Horse Viper Jet Turbine 2230mm (87.8") Wingspan Thread
  • 3D-Seth
    • Mar 2023
    • 35
    Link to purchase:
    Buy Black Horse Viper Jet Turbine 2230mm (87.8") Wingspan - ARF online at Motion RC. Order online with fast delivery.
    Viper Jet Turbine 2230mm (87.8") Wingspan from Black Horse - Balsa Wood ARF - BHM1024-001
    Sleek, fast, and built for serious performance—the Viper Jet is a favorite among RC jet pilots. With its wide flight envelope and forgiving handling, it’s one of the most accessible turbine-powered jets available. Black Horse brings the Viper Jet to life in a giant-scale ARF format with a wingspan just over 2.2 meters (87.8"). Precision-built from lightweight balsa and plywood, the airframe comes factory-covered in a high-contrast, full-scale inspired scheme based on the real-world ViperJet N520VF.
    Optimized for turbine engines in the 120–160N range, the Viper Jet includes electric retracts with CNC-machined oleo struts and a retract controller box for added scale realism and convenience. The internal layout is designed for simplicity and space, making turbine, receiver, and tank installation clean and accessible. Whether you’re stepping into turbines or seeking a sleek, giant-scale jet for your fleet, the Black Horse Viper Jet delivers thrilling performance with unmistakable style and confidence-inspiring handling.
    Visit the Official Black Horse Viper Jet Turbine 120N 2230mm Discussion Thread on HobbySquawk.com for additional photos, videos, reviews, and customer Q&A.
    Striking Real-World Scheme
    Finished in a high-contrast orange and black scheme based on the full-scale ViperJet N520VF for maximum visibility and realism.
    Electric Retracts with Oleo Struts and Brakes
    Fully electric gear with CNC oleo struts, control box, and electronic brakes for smooth operation and precise ground handling.
    Built for Power
    Designed for 120–160N turbines. Easy to install right out of the box.
    Detailed Cockpit Interior
    Features a fully detailed cockpit with painted pilot figure, instrument panel, and realistic seating for ultimate scale realism.
    • Massive 1:3.8 scale design with a commanding 2230mm wingspan
    • Lightweight, strong, precision laser cut balsa and plywood construction
    • Heat-shrink film covering with factory-printed scale details for added realism
    • Fully electric retractable gear with robust oleo struts and controller box (included)
    • Optimized for 120N-160N gas turbine engines (not included)
    • Roomy fuselage with organized servo mounts for clean installation
    • NACA airfoil design for smooth, stable, and precise flight characteristics
    • Included electronic braking system delivers smooth, controlled stops and confident ground handling on any surface.
    • Pre-hinged control surfaces for easy assembly
    • Large, easy-access hatches for straightforward installation and maintenance
    • Painted and detailed cockpit, pilot and interior included
    • Fiberglass control horns
    • Comprehensive control and fitting accessories included
    • Two-piece, plug-in wings simplify transportation and assembly
    • Black Horse Viper Jet Turbine 2230mm (87.8") Wingspan - ARF
    • Electric retract gear with oleo struts and controller box
    • Detailed assembly and instruction manual
    Requires:Customer Note
    Black Horse ARF models are constructed out of balsa wood and plywood. These are not foam models. The assembly of balsa wood ARF aircraft requires basic model building skills including the installation of servos, ESC, and motor (or gas engine). Product Specifications:
    AGE LEVEL : 18 and up
    SKILL LEVEL : advanced
    BUILD TIME : 10+ Hours
    Model Scale 1/3.8 Scale
    Wingspan 2230mm / 87.79in
    Length 2173mm / 85.55in
    Weight 13.5kg / 29.76 lbs
    Wing Area 1,268 sq in / 81.8 sq dm
    CG (Center of Gravity) Refer to manual
    Power System Turbine jet engine with 120–160N thrust (required)
    Electronic Speed Control N/A
    Propeller / EDF Turbine jet engine with 120–160N thrust (required)
    Servos 10x HV high torque (required)
    Landing Gear Electric Retracts with Oleo Struts and Brakes (included)
    Required Battery 2S 6.4v LiFe or 2S 7.4V LiPo, 2200–3200mAh (required)
    Required Radio 10+ Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights Optional
    Hinge Type Nylon Heavy Duty pin hinges
    Material Balsa and plywood
    Skill Level Advanced
    Build Time 10+ Hours
