Official Freewing 64mm BAC Lightning EDF Jet Thread
    • 8218
    BAC Lightning 64mm EDF Jet - Receiver Ready (PNP) from Freewing - FJ10513P
    The BAC Lightning was Britain’s first and only home developed supersonic fighter. Conceived in the late 1940s as a high altitude bomber interceptor, it entered Royal Air Force service in 1960 and remained in frontline use until the late 1980s. Based on the P.1 research aircraft, the Lightning became instantly recognizable for its stacked engine configuration, blistering speed, and powerful climb. No. 92 Squadron operated the Lightning in Germany, where its role shifted from high altitude interception to low level defense.
    The Freewing 64mm BAC Lightning 64mm EDF brings this legend to life in a compact toss and go jet. Finished in that squadron’s authentic RAF livery and faithfully replicating the Lightning’s stacked engine layout, the model delivers standout scale realism in flight.
    A 4S 2840-2700KV outrunner motor paired with a 40A brushless ESC with thrust reversing drives a 64mm 12 blade EDF, producing strong acceleration, crisp handling, and a smooth jet like sound. The true to scale fuselage contour provides a natural hand launch grip, while the lightweight compact airframe enables tight turns, fast passes, and spirited runs that keep every flight engaging.
    Thrilling Agility and Speed
    The Lightning delivers agile, exhilarating flights with speeds reaching up to 100 mph.
    Compact Toss and Go Design
    Lightweight and portable, the Lightning EDF makes it easy to launch and enjoy exciting flights anywhere.
    Authentic and Striking RAF Livery
    The model faithfully reproduces the historic markings of No. 92 Squadron, creating a visually impressive presence in the air.
    Authentic Fuselage Design Allows for Perfect Hand Launches
    The true-to-scale fuselage shape provides a natural grip area for secure and confident hand launches.
    Full Flying Horizontal Stabilizer
    The all-moving stabilizer delivers crisp pitch control and adds to the Lightning’s authentic, high-performance appearance.
    Powerful 4S EDF System
    The 4S 2840 2700 KV outrunner motor paired with a 64mm 12-blade EDF and 40A brushless ESC provides strong acceleration, precise handling, and authentic jet-like sound.
    • Compact toss-and-go design makes it easy to launch and enjoy exciting flights anywhere
    • Reaches speeds up to 100 mph for fast, exciting flights, offering agile handling and responsive performance for thrilling fun
    • Authentic No. 92 Squadron RAF livery delivers a visually striking, historically accurate appearance
    • Full flying horizontal stabilizer enhances pitch authority and scale realism
    • Scale fuselage contour maintains the proper scale shape while also providing a natural hand-launch gripping location for secure and confident tosses
    • The full-scale stacked motor layout is faithfully replicated while optimizing EDF airflow for smooth performance
    • Quick and easy assembly allows you to get airborne quickly, and without hassle
    • The 4S 2840 2700 KV outrunner motor paired with a 40A brushless ESC including thrust reversing provides strong acceleration and responsive, jet-like handling
    • The 64mm 12-blade EDF delivers precise control along with authentic jet sound
    • The spring-loaded battery hatch allows fast and hassle-free battery changes, keeping you flying with minimal downtime
    • Compatible with common 4S 1800-2200mAh LiPo batteries utilizing an XT-60 connector
    • Durable EPO material offers superior strength and durability
    • Freewing BAC Lightning 64mm – PNP
    • 12-Blade 64mm EDF Power System (Installed)
    • 2840-2700KV Outrunner Motor (Installed)
    • 40A ESC with reverse thrust and XT-60 Connector (Installed)
    • Freewing Smart Servos (Installed)
    • Fixed Landing Gear
    • Instruction Manual
    AGE LEVEL : 14 and up
    SKILL LEVEL : Intermediate
    BUILD TIME : 1 Hour
    Scale 1/18
    Wingspan 583mm / 22.95in
    Length 817mm / 32.17in
    Weight 500g /1lb 2oz (without battery)
    CG (Center of Gravity) 207mm (8.15") from the leading edge of the wing at the root
    Power System 4S 2840-2700Kv brushless outrunner motor
    Electronic Speed Control 40A Brushless ESC (with Thrust Reversing)
    Propeller / EDF 64mm 12-Blade
    Servos
    • Ailerons, Elevator: 9g digital standard servo with 500mm lead - FSS31091-500
    • Nose Gear Steering: 9g digital standard servo with 200mm lead - FSS31091-200
    Landing Gear Fixed, Removable Landing Gear
    Required Battery 4S 14.8v 1800-2200mAh LiPo battery
    Required Radio 4 channels (5 with thrust reversing)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps No
    Lights No
    Hinge Type Elevators – Full Flying on Metal Pivot Rod
    Ailerons/Rudder – Live Foam Hinge
    Material EPO Foam
    Skill Level Intermediate
    Build Time 1 Hour
    Recommended Runway Surface Hard Surfaces or Hand Launch
  • tab28682
    RC addict
    • 334
    • Fort Worth, TX
    At last!
