Banshee 64 mm ESC problems
  • ALAN B
    • Mar 2026
    • South Alabama
    I'm having problems with the ESC on my new banshee. When I go into full throttle it turns into reverse but if I take off the throttle reverse pin it stays in full thrust and works fine. I've checked everything even used a different brand of receiver. Same problem. Any suggestions? And yes, the momentary reverse throttle switch works properly. TX15 and er8 erls system
    • 5426
    You have throttle mixed to your reverse channel.
    • ALAN B
      • Mar 2026
      • South Alabama
      No I have it set to the SD momentary switch I have. That's the only reverse I got set up
        • 8835
        No experience with FrSky. My reply was irrelevant.
          • 5426
          FRSky SD is a top left switch. He has throttle mixed to it along with reverse.
