Official Freewing 80mm JPLAAF JL-8 EDF Jet Thread
    JPLAAF JL-8 80mm EDF Jet with Gyro - PNP from Freewing - FJ22411PG
    Coming Soon — Estimated Arrival Late July 2026:
    • Good things are worth waiting for. Be the first to know when the Freewing PLAAF JL-8 80mm EDF hits the shelves — sign up for email notifications and we'll let you know the moment it arrives.
    From its first takeoff to its final touchdown, the Freewing JL-8 80mm delivers the kind of confidence-inspiring flight experience that makes you eager to charge another battery and fly again. Inspired by the full-scale JL-8 Karakorum advanced jet trainer, an aircraft developed to prepare military pilots for the transition to modern fighter aircraft, this impressive EDF captures the spirit of its full-scale counterpart with smooth, predictable handling, impressive speed, and the excitement expected from a modern military jet. In the air, the JL-8 has quickly earned a reputation as one of the finest flying EDF models Freewing has produced, offering exceptional stability, precise control response, and a remarkably enjoyable flying experience.
    The beautifully crafted airframe faithfully recreates the sleek lines of the Hongdu JL-8 with crisp panel lines, numerous molded surface details, a detailed tandem cockpit, and a striking red, white, and blue demonstration livery that commands attention both in the air and on the ground. A brilliant LED lighting package with scale navigation lights further enhances the realism and presence of the aircraft, making the JL-8 as impressive sitting on the flight line as it is carving through the sky.
    Beneath its scale exterior lies a powerful 6S power system featuring a 3658-2150Kv inrunner motor, high-efficiency 80mm EDF unit, and a 100A ESC with thrust reversing capability. The result is strong acceleration, impressive speed, realistic turbine-like sound, and improved ground handling with shorter landing rollouts.
    Freewing's latest innovations make the JL-8 incredibly convenient to own and operate. Screwless quick-release wings allow fast, tool-free assembly and disassembly for easy transportation and storage, while the factory-tuned EG01 gyro system enhances stability and pilot confidence without compromising the JL-8's crisp handling and connected flight feel. A large, easy-access battery hatch provides quick and convenient battery changes at the flying field.
    With exceptional flight characteristics, outstanding scale realism, and the latest Freewing technology, the Freewing JL-8 80mm is more than just another EDF jet; it is the kind of aircraft that will quickly become the one you reach for every time you head to the flying field.
    Screwless Quick-Release Wings
    Innovative quick-release wings allow fast, tool-free assembly and disassembly, making transport and storage simple and convenient.
    Factory-Tuned EG01 Gyro System
    The pre-installed EG01 gyro is expertly configured for the JL-8, delivering enhanced stability and a more connected flight experience while preserving the jet’s crisp handling and exciting performance characteristics.
    Highly Detailed Airframe
    Expertly crafted with crisp panel lines and numerous molded surface details, the Freewing JL-8 delivers impressive scale realism.
    High Performance 6S Power System
    The high-performance 80mm 12-blade EDF system delivers strong thrust, smooth power delivery, and a realistic turbine-like sound for an immersive jet flying experience.
    Brilliant, Scale LED Lighting Package
    A LED lighting system enhances scale realism, featuring navigation lights that bring the JL-8 to life both in the air and on the ground.
    Large Easy-Access Battery Hatch
    A spacious battery hatch provides quick and convenient battery access, making battery installation and changes fast and easy at the flying field.
    • Screwless quick-release main wings allow fast and convenient field assembly and disassembly for easier transport and storage
    • Freewing EG01 6-axis gyro provides a stable and enhanced flying experience
    • 3658-2150Kv inrunner motor for high-performance, speed and efficiency
    • 100A ESC with 7A UBEC, thrust reversing and EC5 connector for advanced control
    • 80mm 12-Blade EDF
    • Spacious battery bay allows easy battery installation and accommodates a wide range of pack sizes
    • Highly detailed airframe with sharp panel lines and molded surface details deliver impressive scale realism
    • Excellent low-speed stability and high-speed agility provide a wide performance envelope for both scale flying and more advanced aerobatic maneuvers
    • Durable multi-material construction using EPO foam, aluminum, carbon fiber, steel, nylon, plastic, and wood provides exceptional strength with optimized weight
    • Freewing PLAAF JL-8 80mm EDF Jet with Gyro – PNP
    • 12-blade 80mm EDF Power System (installed)
    • 3658-2150Kv Inrunner Motor (installed)
    • 100A ESC with reverse thrust and EC5 connector (installed)
    • Freewing EG01 Gyro (Installed and Programmed)
    • Electronic, retractable landing gear (installed)
    • Servos (installed)
    • Instruction Manual
    Requires:Power System and Electronics Compatibility:
    This model is designed to operate using the included ESC and its integrated BEC, which is specifically matched to the onboard electronics. To ensure reliable performance and prevent damage, always power the aircraft's receiver and electronics through the installed ESC using the main flight battery. Do not use any power source other than the main flight battery to power the model, otherwise damage will occur to the electronics.
    The receiver, servos, and other onboard electronics included with this model are rated for a maximum input voltage of 5.5V. When selecting your ESC and power system, verify that the BEC output supplied to the receiver and onboard electronics does not exceed 5.5V. Using a higher voltage will damage the aircraft's electronics. Product Specifications:
    AGE LEVEL : 14 and Up
    SKILL LEVEL : Intermediate
    BUILD TIME : 1+ Hours
    Model Scale 1/9
    Wingspan 1130mm / 44.5in
    Length 1238mm / 48.7in
    Weight 1877g (4.1lbs) without battery
    CG (Center of Gravity) 78mm aft of the leading edge of the wing at the wing root
    Power System 3658-2150Kv Inrunner Motor w/80mm 12-blade Fan (included)
    Electronic Speed Control 100A Brushless with 7A UBEC and thrust reversing (included)
    Propeller / EDF 80mm 12-Blade EDF (included)
    Servos
    • Nose Gear Steering – FSS31093-200
    • Nose Gear Door - FSS31091-300
    • Ailerons - FSS31093-400
    • Flap (Left) – FSS31093-200
    • Flap (Right) – FSS31093R-200
    • Elevator (Left) - FSS31093-200
    • Elevator (Right) – FSS31093R-200
    • Rudder – FSS31093-100
    Landing Gear CNC-Machined Aluminum, Shock Absorbing, Retractable Landing Gear (included)
    Required Battery 6S 22.2V 5000mAh LiPo with EC5 Connector (EPR50006) (required)
    Required Radio 6-8 channels (6 for flight; +1 per optional feature (Gyro Modes, Thrust Reversing) (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Lights Yes
    Hinge Type Nylon
    Material EPO Foam
    Skill Level Intermediate
    Build Time 1+ Hours
    Recommended Runway Surface Hard Surfaces
  • nickwildman81
    • Nov 2025
    • 17
    • North West, UK
    Do you think this would be an ideal first EDF? I know there's the unrivalled Avanti, but, I much prefer scale....
      • 5426
      If it flies like a L-39 yes.
      • Greywar54
        • Feb 2025
        Can you put wing tanks on like the first one
          • 5426
          The first one? This has wing tank.
          • Quickstopdf
            • Jun 2023
            Drop tanks, yes, tip tanks, no.
            • MarkyM
              • Jun 2025
              Hi. What a great looking model. I was about to buy me another Avanti V2 (ace!) but on seeing this beaut, I would def rather own this. My one concern is the U/C. My Avanti has been flying off our grass patch for over a year with no issues whatsoever. Would the JPLAAF JL-8 be ok to fly off grass?
