No information on retractable landing gear
  • Bigge13
    • Jun 2022
    • 4
    I’m trying to find some gear to match replace I am working. I have one that works and when it doesn’t and I’m trying to find something that’s gonna be about the same change the hole in the wing for the retractable land gear what would make that a lot easier as if you need a dimensions and how long a fit on our yard you don’t have any of that nothing I don’t know how to find it on any of your landing gear
    • 8835
    Starting a second thread in the same day is not going to get you any answers any faster.
    It's also very hard to understand what you are after when you don't specify what kind of plane you have. Maybe if you can give more specific details, people may be more willing to help out.
    • kallend
      • 1877
      It's very hard to understand - period.
      • Bigge13
        • Jun 2022
        • 4
        Yeah, I guess I should have proofread my post before I sent it. My bad.
        What I’m asking for is more information on their landing gears. I am referring to freewing. They just show you pictures and they give you a brief description in the heading without any specification about his length or size of the mounting bracket . As for the type of retract I want to replace it is the main gear on a blitzwork twin 70 mm F4. blitzwork no longer carries the parts and aircraft has been discontinued.
        Any suggestions where I can the date or perhaps someone who might have the parts would be much appreciated.
        • Bigge13
          • Jun 2022
          • 4
            • 8835
            BlitzRCWorks is a Banana Hobby inhouse brand. They don't even list the plane anymore (likely discontinued) and the parts list for the plane doesn't list retracts. If you go to the electronic retracts section of MotionRC, you will see almost every available retract they sell. On each product page, they DO show dimensions. You'll have to check each one and compare the dimensions to yours.
            Shop RC Airplane Electronic Retracts at Motion RC. Discover electric landing gear systems and retract units for reliable RC aircraft performance.
            Failing to find an exact match, you'll have to find the closest and do some modifications to make it fit.
              • 5426
              Post dimensions and exactly what you are looking for and a picture. Make sure to say if you just want the retract unit, the strut, wheels, or all of it and the mounting hole dimensions from center to center of the hole long wise and width wise.
