Official Freewing Twin 80mm MiG-29 Fulcrum Digital Camo EDF Jet V2 with Gyro Thread
    MiG-29 Fulcrum Digital Camo Twin 80mm EDF Jet V2 with Gyro – PNP from Freewing - FJ31616PG
    The Mikoyan MiG-29 is a legendary twin-engine air superiority fighter that has defended the skies for over a dozen air forces since 1981. Its wide lifting-body fuselage, twin canted tails, and aggressive intake ramps give the Fulcrum one of the most distinctive silhouettes in modern military aviation — a look this large-scale model captures in commanding fashion.
    The Freewing MiG-29 Fulcrum Digital Camo V2 builds on the acclaimed original with a focused round of upgrades that improve durability, realism, and field convenience without changing what made this twin 80mm EDF jet a fan favorite. A factory-installed EG01 6-axis gyro adds a new layer of confidence on approach and during precision maneuvering, without taking anything away from the model's high-performance character, while Freewing's quick-release main wing system makes assembly and breakdown faster than ever.
    V2 also introduces additional LED navigation lighting across the fuselage spine, belly, and rudder for improved visibility and scale realism in flight. Underneath the striking Digital Camo livery, the airframe itself has been reinforced: a redesigned nose gear strut and wheel, a CNC metal cover protecting the main electric retracts, and a wooden plate-reinforced wing spar with an updated landing gear mount all combine to give this MiG-29 a stronger foundation for grass-field operation.
    Powered by the proven twin 80mm 12-blade EDF and 3658-2150Kv inrunner motor combination, the Digital Camo V2 delivers the same rapid acceleration and 120mph top speed that made the original a standout. Finished in a stunning five-tone "Digital Thunder" camouflage scheme in service with the Slovak Air Force, this MiG-29 stands apart in any EDF fleet — now backed by a more durable airframe and a smoother, more refined performance envelope.
    Size That Commands the Field
    At nearly 75 inches long with a 50-inch wingspan, the MiG-29 Fulcrum commands serious presence on the flight line. This is a jet that looks every bit as dominant parked on the ramp as it does screaming overhead.
    Confidence at Scale
    The factory-installed EG01 6-axis gyro smooths the flight envelope and adds precision on approach, making the Digital Camo V2 more locked in without dulling any of its high-performance character.
    Quick-Release Wings
    Freewing's quick-release main wing system makes assembly and breakdown faster than ever. Tool-free and straightforward — spend less time setting up and more time flying.
    Lit Up and Ready
    Additional LED navigation lighting across the fuselage spine, belly, and rudder improves visibility and adds another layer of scale realism, whether flying at dusk or making a low pass down the runway.
    Reinforced Nose Gear
    A redesigned nose gear strut and wheel, paired with a CNC metal cover protecting the main electric retracts, deliver tougher, more confident ground handling on grass and hard-surface runways alike.
    Scale Ordnance on Removable Pylons
    The MiG-29's Archer missiles were a deadly threat in close-in dogfights. A complete scale ordnance package and removable pylons come standard on every Freewing MiG-29.
    Bold, Eye-Catching Scheme
    Set yourself apart from the crowd with this meticulously factory-finished five-tone "Digital Thunder" camouflage livery, worn in service with the Slovak Air Force.
    Twin 80mm Power, Proven Performance
    The MiG-29's twin 80mm 12-blade EDF and 3658-2150Kv inrunner motor combination delivers rapid acceleration and speeds approaching 120mph — the same fan-favorite power system trusted across the Freewing EDF lineup.
    • NEW V2! Factory-installed EG01 6-axis gyro for a more refined, confidence-inspiring flight experience
    • NEW V2! Freewing's Quick-Release main wing system allows fast, tool-free assembly and disassembly for convenient transport and field setup
    • NEW V2! Additional LED navigation lighting across the fuselage spine, belly, and rudder improves visibility and scale realism in flight
    • NEW V2! Redesigned nose landing gear strut and wheel for improved ground handling
    • NEW V2! CNC metal cover reinforces the main electric retract units for increased durability
    • NEW V2! Wooden plate-reinforced wing spar and redesigned main landing gear mount strengthen the airframe for grass-field operation
    • NEW V2! CG reference marker now located on the underside of the wing for faster, easier field setup
    • Stunning five-tone "Digital Thunder" camouflage scheme in service with the Slovak Air Force
    • Twin 80mm 12-blade EDF power system with 3658-2150Kv inrunner brushless motors delivers speeds approaching 120mph
    • 1/9 scale with 74" length and 50" wingspan — commanding presence on the ground and in the air
    • Lifting body design provides gentle flight characteristics and excellent directional stability
    • Large flaps and suspension landing gear give pilots confident operation on grass airfields
    • Accurate overall outline, scale ordnance on removable pylons, and articulating landing gear doors enhance scale fidelity
    • Twist-and-Turn main retracts provide improved aerodynamics with servo-driven gear doors
    • Freewing MiG-29 Fulcrum Digital Camo Twin 80mm EDF Jet V2 – PNP
    • Twin 80mm 12-blade EDF units with 3658-2150Kv inrunner brushless motors (installed)
    • Twin 100A ESCs with 8A UBEC (installed)
    • Factory-installed EG01 6-axis gyro
    • Electric retractable suspension landing gear with CNC metal reinforcement (installed)
    • Servos and LED navigation lighting (installed)
    • Instruction manual
    Requires:
    • 6-8 Channel radio (7 required for thrust reversing, 8 required for gyro mode selection) select a minimum 6 channel radio from our Aircraft Radio Collection
    • 6-8 Channel receiver (7 required for thrust reversing, 8 required for gyro mode selection) - Select a minimum 6 channel receiver from our Aircraft Receiver Collection
    • TWO 6 Cell 22.2V 4000 - 6000 mAh LiPo Batteries with EC5 Connectors - we recommend TWO Admiral 6 Cell 6000 mAh LiPo batteries
    • 6 Cell compatible battery charger - select a minimum 6 cell (6S) charger from our Charger Collection
    Power System and Electronics Compatibility:
    This model is designed to operate using the included ESC and its integrated BEC, which is specifically matched to the onboard electronics. To ensure reliable performance and prevent damage, always power the aircraft's receiver and electronics through the installed ESC using the main flight battery. Do not use any power source other than the main flight battery to power the model, otherwise damage will occur to the electronics.
    The receiver, servos, and other onboard electronics included with this model are rated for a maximum input voltage of 5.5V. When selecting your ESC and power system, verify that the BEC output supplied to the receiver and onboard electronics does not exceed 5.5V. Using a higher voltage will damage the aircraft's electronics. Product Specifications:
    AGE LEVEL : 14 and Up
    SKILL LEVEL : Advanced
    BUILD TIME : 1 Hour
    Model Scale 1/9
    Wingspan 1257mm / 49.4in
    Length 1878mm / 73.9in
    Weight 4700g / 151.6oz
    CG (Center of Gravity) 140mm (5.5in) From leading edge at the wing root
    Power System 2x 3658-2150Kv brushless inrunner motors (included)
    Electronic Speed Control 2x 100A with 8A UBEC (included)
    Propeller / EDF 2x 80mm 12-Blade EDFs (included)
    Servos
    • 9g hybrid gear standard with 200mm lead : left cabin door - MD31093-200
    • 9g hybrid gear reverse with 200mm lead : right cabin door - MD31093R-200
    • 9g digital metal gear standard with 300mm lead : thrust vectoring - MD31092-300
    • 30g coreless metal gear standard with 100mm lead : left elevator - MD31303-100
    • 30g coreless metal gear reverse with 100mm lead : right elevator - MD31303R-100
    • 17g metal gear standard with 200mm lead : left rudder, right rudder, left flap, right flap, nose gear steering - MD31172-200
    • 17g metal gear standard with 400mm lead : left aileron, right aileron - MD31172-400
    Landing Gear Electric retractable suspension gear with CNC metal reinforcement (included)
    Required Battery TWO 6 Cell 22.2V 4000 - 6000mAh LiPo batteries with EC5 Connector (required)
    Required Radio 9 Channel (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights Yes — Nav (wings, fuselage, belly, rudder)
    Gyro Yes Freewing EG01 (included)
    Hinge Type Nylon
    Material EPO Foam
    Skill Level Advanced
    Build Time 1 Hour
    Recommended Runway Surface Well manicured short grass and hard surfaces
  • fredmdbud
    • 451
    https://www.youtube.com/watch?v=BMy967cYXZI
    • Racer686
      • 32
      I am trying to line up the V2's new TV nozzles, one was toed out a bit compared to the other. I do not see any markings for the centered positions on the nozzles and there is no sticker denoting it as there was on the Ares nozzle. Any help would be appreciated.
