If you did this how does your radio, telemetry and esc LVC appear and is it smart telemetry so that it gives you individual cell readings/warnings to ensure you know the 6s pack is running out or is it based on total voltage of both packs together and will you get LVC warning at the right time ? I would have thought same mah for both lipos takes out the risk of a false reading but I guess it is down to what you are comfortable with. Maybe run em down to lvc on the ground first ?
Official 90mm Avanti S EDF Sport Jet Thread
Can anyone tell me what is the maximum usable width of the battery compartment in the 90mm Avanti-S?Comment
Today we had a very nice and pretty warm weather (as for this season): 9 degrees C with lots of Sun and no wind.
Perfect weather for the maiden.
I've also the 80mm version so I'll be comparing those 2.
All settings as per manual. Battery 6s 5500mAh. Take off weight 3.9kg
First positive surprise: Plane takes off by itself without the need to pull the elevator (diving nose wheel of 80mm version was a nightmare to take off on grass compared to this).
CG seem to be pretty good (way better than original one of 80mm version)
Throws - as suspected - too much ailerons and elevator on low rate for me. Reduced by around 20% each. Now, the roll rate is ab. 0.8-1 rotation per second. Haven't tried high rates (most likely I'll program the original low rates as high rates).
After landing, I've noticed that the elevators are visibly down (from the zero point). I'm wondering if it's CG or something else.
I've also had to trim the ailerons to the right. Could be either the EDF torque or the flaps aren't 100% level (to be checked).
Landing was another surprise compared to 80mm version. First, I tried to land with a bit of throttle and full flaps. Plane just went through the whole runway and I had to go around. Second try was on zero throttle and only then it landed nicely (but still gliding pretty well).
Perhaps adding flaps would help to slow it down?
Second flight was to check gyro. Model was even more rock solid (this plane doesn't seem to need gyro at all).
Regarding the power system - 6s is definitely not overpowered
It has nice vertical but pretty limited.
I'm going to swap the fans and use the 4068-1750kV version on 6s to see what changes.Cheers!
MarekComment
Folks, if you're looking for a wing protection bags.
Here's what I got. They seem to fit perfectly (the "30E and smaller" size").
It does fit both wings and the wing tube (separate pockets)
Cheers!
MarekComment
Looks like someone else experienced similar issues on maidenToday we had a very nice and pretty warm weather (as for this season): 9 degrees C with lots of Sun and no wind.
I'm going to swap the fans and use the 4068-1750kV version on 6s to see what changes.Comment
When will the TV systems be available for preorders? When will we see a comparison between the 6s and 8s versions? Is there going to be any mods needed for the 8s version to get the Cg correct for the best flying setup? I have the green 8s version in the box awaiting release of the TV module and info on the above questions. Also wondering what you guys think about the new gyro? Will we need a second gyro for the TV? TIA!!!!Comment
