Hi Gang Getting prepped to maiden my Freewing ME262 and I have some questions. Re the CG are you going by the manufacturer specs of 100 - 110mm or is it different from that? I see Rich Baker advises using the two slots on the bottom of the wing about 95 mm back as his reference point, so its a little confusing.
Also when taking off are you always using half flap? What about landing in low wind and high wind conditions. Do you ever use full flap?
Thanks for your help! Bluebird
