I just bought the FMS F-15. I am using a Spektrum receiver with remote and 3s 2200 Lipo. Any suggestions on where to locate the receiver so the Lipo will fit?
FMS F-15
Good luck; I just crashed one, because the battery separated the connector to the aileron servos at take-off, as I had the receiver in front of the nose wheel, and used an extension. I would suggest, wherever you place the receiver, that you cut a hole to route the cables out of the battery chamber. After the crash, I thought of mounting the receiver in one of the air intakes; hard to hook up, but it shouldn't need access after assembly.
