B-17 Flying Fortress
  • B-17 Flying Fortress
    I just purchased the b-17 flying fortress and don't know how to route the engine wires to the esc without interfering with the retracts.
    I ran them between the retract and the necel by cutting a little of the foam away and then tucked them nicely in and they are covered by the wheel well trim. R.
    AMA 424553
      I'm trying to picture the issue your having. Most of the time, I use mini zip ties, to pull them and hold them away from the mechanical arm. I would remove the retract and file or dermal tool a small section so the wires recess. Anytime I have a wire issue, it's the wires I can move. The gear has a fixed point that requires room to operate. The wires can be extended or moved. Take your time, it's a beautiful flying model.
      Take care, Matt Customer Service. Give me a call, if you require additional assistance.
