I have a freewing F-35 that I can't seem to trim out properly. I can trim it for stabile flight, however when I throttle back the nose pitches up. I have the thrust vectoring set at factory specs. I tried adjusting the thrust vectoring up a few degrees and then trimmed the elevator. It had little effect, the nose still pitches up when the throttle is pulled back. I also tried adding a little nose weight, which seemed to help a little, but not enough. I'm wondering if adding more nose weight might cure the problem, but worry about going too far and losing elevator when landing.
Has anyone had this issue and have you found a solution?
Thanks for your input.
