Can anyone tell me if the A6 Kit version comes with all of the gear and front gear door pre-assembled? Second question: Does it come with any servos pre installed at all?
•Super scale details include two hand painted pilots, full instrument panel, refueling probe, scale drop tanks, airfoil panel lines, and complete USS Forrestal graphics package
•6-Blade, 80mm EDF comes pre-installed. Optional 12-blade metal EDF unit available as an upgrade
•Electronic retractable landing gear with all metal shock-absorbing struts
•Steerable, shock absorbing nose gear for enhanced ground maneuverability
•Full function drop down flaps allow shorter take-off distances and slow, scale landings
•Full function linked horizontal stabilizer/elevator gives incredible climb and descent capability and true to life scale detail
•Carbon spars and EPO foam construction provide the perfect balance between strength and flexibility
•Optional weapons set can be added for increased realism
•Nylon hinges on all control surfaces (superior to foam hinges)
Requires:
•Brushless motor, ESC and servos (see specifications tab for details)
•Minimum 6 Channel Radio - Click Here for recommendations
•6 Channel Receiver - Click Here for recommendations
•6 Cell 22.2V 4000 mAh LiPo Battery with EC5 connector - Click Here for recommendations
•Lipo Battery Charger - Click Here for recommendations
Yeah - I saw that...some of the set up for the gear looks complicated. I wa=
s hoping that some one who has purchased the kit could tell me exactly what=
came in the box and if the gear and front door was already installed. =0A=
=0A=C2=A0=0AI previously purchased the ARF version but crashed it. the fron=
t end is beyond repair. just trying to figure out how much of the old plane=
I need to put back into the kit version. =0A=0A=0A=C2=A0=0A=0A=0AOn Tuesda=
y, June 10, 2014 7:23 AM, Rocketeer [via Motion RC Community Forum] <ml-nod=
e+s1075610n2440h95@n5.nabble.com> wrote:=0A =0A=0A=0AGreetings John, =0A=0A=
From the product page: =0A=0AFeatures: =0A=C2=A0=E2=80=A2Super scale detail=
s include two hand painted pilots, full instrument panel, refueling probe, =
scale drop tanks, airfoil panel lines, and complete USS Forrestal graphics =
package =0A=C2=A0=E2=80=A26-Blade, 80mm EDF comes pre-installed. Optional 1=
2-blade metal EDF unit available as an upgrade =0A=C2=A0=E2=80=A2Electronic=
retractable landing gear with all metal shock-absorbing struts =0A=C2=A0=
=E2=80=A2Steerable, shock absorbing nose gear for enhanced ground maneuvera=
bility =0A=C2=A0=E2=80=A2Full function drop down flaps allow shorter take-o=
ff distances and slow, scale landings =0A=C2=A0=E2=80=A2Full function linke=
d horizontal stabilizer/elevator gives incredible climb and descent capabil=
ity and true to life scale detail =0A=C2=A0=E2=80=A2Carbon spars and EPO fo=
am construction provide the perfect balance between strength and flexibilit=
y =0A=C2=A0=E2=80=A2Optional weapons set can be added for increased realism=
=0A=C2=A0=E2=80=A2Nylon hinges on all control surfaces (superior to foam h=
inges) =0A=C2=A0 =0ARequires: =0A=C2=A0=E2=80=A2Brushless motor, ESC and se=
rvos (see specifications tab for details) =0A=C2=A0=E2=80=A2Minimum 6 Chann=
el Radio - Click Here for recommendations =0A=C2=A0=E2=80=A26 Channel Recei=
ver - Click Here for recommendations =0A=C2=A0=E2=80=A26 Cell 22.2V 4000 mA=
h LiPo Battery with EC5 connector - Click Here for recommendations =0A=C2=
=A0=E2=80=A2Lipo Battery Charger - Click Here for recommendations =0A=0AHop=
e this helps..... =0A=0AClear Skies =0A=0A________________________________=
=0A =0AIf you reply to this email, your message will be added to the discus=
sion below:http://motion-rc-community-forum.1075610.n5.nabble.com/Freewing-=
A6-tp2439p2440.html =0ATo unsubscribe from Freewing A6, click here.=0ANAML
Sorry to hear of your mishap.
There is no better support on the planet than MRC's.
Just give them a call and I'm sure you'll learn all you need to know.
