Does any one run an Admiral 4s 1600 in there panther
f9f freewing
Re: f9f freewing
Hey Coleman. I read the thread and have some concern on what you stated is in your Panther. Are you sure that the motor you used is a 5100 kV? If so, that would put the max. rpm north of 60,000 rpm. INSANE! Most 4S setups use a motor in the low 4000 kV range. I would suggest you check to be sure. The last thing one would want is for the fan to let loose and spew parts all over the place and shred your plane, or you.
Good luck.
Re: f9f freewing
I had those concerns as well. I don't run at full throttle very often. I can honestly cruise at 1/4 to 1/2 throttle. I generally only go full out on takeoffs, high speed passes (you get 2-3 per battery) or climbs. The guys at the field said that it would put it over the 50k rpms which most fans tend to explode.
Oh and currently it's in the Mig-15. I have been considering putting it into the Panther. I really hate hand launching.
It's the motor from this plane, the esc was to large so I used a smaller one that I had and it doesn't get hot since it's in the tube:
http://www.motionrc.com/fms-f35-lightning-grey-64mm-edf-jet-v2-pnp/
